Question about Canon PIXMA MP210 Photo All-In-One Printer
How to get the ink cartridges to the home position
Need to know what to do to have the ink cartridges in the home position to remove and replace with new ones.
Thanks for your call back. I did find a solution after my request for help I read through the website and under solutions read and tried the solution posted by ICHIBANDESI which worked for me. I had been unable to have the cartridge holder remain on the left-hand side after turning the printer off. With the printer turned on it remained to the left and I was able to remove and replace the cartridges without any further problems and it prints okay.
Thanks again for the helpful suggestions on your site.
Sue
Posted on May 24, 2009
Having trouble removing ink cartridge on hp e709n printer
Hello Sandi,
According to the product information you provided in your post, the following information should be able to provide you with the information needed to help you remove and replace the ink cartridges for your printer.
Ink Cartridge Removal Steps:
Keep your printer plugged in and on during this process.
1. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage stops moving before proceeding.
Illustration of cartridge access door
2. Each ink cartridge will have plastic tabs located directly in front of them. Press in the tab on the front of one of the cartridges, and then pull it out and up to remove it from its slot. Once you have pressed the tab, you then pull up and out on the cartridge and it should come out easily.
Illustration of process:
3. Repeat this step to remove all cartridges from their slots. Remember that each ink cartridge will have to be removed individually if your printer has more than one cartridge.
Replacing the cartridge with the new one:
1. Remove the ink cartridge from the packaging and then remove the protective covering.
2. Hold the ink cartridge in the same position as you removed the old ones. Push in and then down on the new ink cartridge which should lock them into position with the tabs automatically and you will you will usually hear a clicking noise when this is done.
3. Close the cartridge access door. The printer will automatically reposition the cartridge print head assembly for you.
This should complete the process and you should now be able to print. Some printer will ask or recommend that you print a test page so that it can calibrate the desired ink usage, position, darkness, etc. If this appears on your screen just follow the directions as prompted to complete the test page.
I hope this provides you with a bit more clarity for removing and reinstalling your printer ink cartridges. If you have any further questions or need additional assistance, please feel free to ask. Have a good day.
Jun 20, 2012 | Unknown Office Equipment & Supplies
Need to replace ink cartridge and I forget how to replace ink cartridge
1. Remove the black ink cartridge from its bag.
2. Carefully remove and discard the orange cap.
Handle ink cartridges carefully to avoid ink transfer.
3. Insert the black ink cartridge into the printhead.
4. Press down on the ink cartridge until you hear it click
into position.
5. Open and uncap the color ink cartridge. Insert it into
the printhead.
6. Press down firmly on the ink cartridge until you hear it
click into position.
7. Close the printer access door.
Here's the link if you want some illustrations. Link
Chapter 3, Page 5
Thank you for posting..
Jun 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
I don't know how to load the ink into the printer of the iP 1600 Canon pixma
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Apr 25, 2011 | Office Equipment & Supplies
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Can't get ink into printer
With the ink cartridges in the home position, push down on the back of the old cartridge till it snaps down. remove the old cartridge and place the new one into position and snap it up.
May 05, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Installation of the cartridge for Canon Pixma iP1600 printer
To print normally, install or remove ink cartridges in an orderly procedure.
cartthingsnottotouch.jpg3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
ip1600puttinginink.gif4. Confirm that the ink cartridges are installed properly.
Jan 06, 2009 | Canon PIXMA iP1600 Printer
Don't know how to move the cartridges to replace the ink.
Please follow the instructions below to ensure correct installation:
  1. Lower the printer's output tray and open the top cover.
  2. Connect the power cable to the printer.
And switch on the printer.
The print heads will now move to the replacement position. If they do not move to a change position press the Red ink button on the printer.
  • Lift up the ink cartridge clamps.
    Before you open the new ink cartridge package, shake it four or five times. Then remove it from the package.
    on the side of the cartridge. This can damage the ink cartridge.
    You must remove the yellow tape from the cartridge before installing it; otherwise, print quality may decline or you may not be able to print.
    If you have installed an ink cartridge without removing the yellow tape, take the cartridge out of the product remove the yellow tape, and then reinstall it.
    Do not remove the transparent seal from the bottom of the cartridge or the label on the cartridge; otherwise the cartridge may become unusable or ink will leak.
    Place the ink cartridge into the cartridge holder with the bottom down. Then push down the ink cartridge until it clicks into place.
    Repeat steps 4 to 6 for each ink cartridge.
  • Close the ink cartridge cover and press it until it clicks into place
      If you find it difficult to close the cartridge cover, make sure all the cartridges are firmly seated. Press down on each cartridge until you hear it click into place. Do not attempt to force the cover closed.
    1. Close the printer cover and press the ink or start button to begin charging the system. Charging can take up to three minutes and is complete when the power light stops flashing.
    While the ink system is charging do not switch off the printer.
    Sep 16, 2008 | Epson Stylus 880 InkJet Color Printer
    Dell 725 printer no manual need to change ink cartridge
    Here is the manual
    http://support.dell.com/support/edocs/systems/725/en/index.htm
    Replacing an Ink Cartridge
    2. Lift the front cover.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Close the front cover.
    Feb 09, 2008 | Dell 725 InkJet Printer
    Canon PIXMA MP210 Photo All-In-One Printer Logo
    66 people viewed this question
    old marine
    old marine
