Question about Mitsubishi WS-55908 55" Rear Projection Television
Mitsubishi 55908 powers on then powers off
TV powers up for about 2 - 3 seconds then powers off.  Problem code is 22.  From my other findings, this is a short.  I believe I can fix it myself with a little direction.  Can someone talk me through it?
  • problem351 Oct 20, 2007
    so how can I fix the short? resolder th ic heat sink?
    my problem was the power turning off 3 seconds after I turn it on.This was my instruction:
    A short causes an open fuse. In this case, one or two open
    pico fuses in power supply. Usually,the short is one of the
    convergence IC's== STK unit(s) mounted to large heat sink on
    middle PCB.Check it out and let me know if you need more help........T.
    I was a car stereo installer for many years and understand how to operate a meter and how to solder.  If someone can tell me exactly how to fix it I would really appreciate it.
    Genius:
  • 1,694 Answers
Posted on Oct 20, 2007
  • Vista Electronics Oct 20, 2007
    Does your set power off  or  shutdown?
    Power off means you can power back up for 2 seconds by
     pushing the power button...
    Shuts off or shutdown can mean you must unplug the ac cord
     to get it to power up for 2 seconds again...
    Power off generally is caused by a missing voltage,i.e. an
     open fuse in the power supply circuitry.Identifying which fuse
     is open will help diagnose which part shorted.Ex.=== if one or
     both of the fuses protecting the B+ to the convergence IC's are
     bad, then the convergence IC's need to be changed..
    If the set goes into shutdown,then more likely the problem is
     in the horizontal circuitry,which is on the main or HV scan PCB,
     the one with the flyback xformer on it. As you can see,
     diagnosis is key.  Hope this helps you along...T.
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I have a 65611 Big Screen TV. The TV shut itself off. Pressed the reset button, It flashes green then off. Pressed power again and it just shuts off. Unplugged the tv and replugged. Have a power strip...
Hello it looks like you a problem with your main board, maybe a horizanal deflection. you can get the problem by run troubleshoot codes, first hold the buttons mune and input or device until starts blinking account the blinks, it will blink few times and the it will pause for a second again will blink. get blinking number like, 2 the 2, or 2 then3. that means 22 or 23. 22 means convergance problems. feel free to call me if you need more help with your tv. 602-810-7149 i live in mesa az
Dec 31, 2010 | Mitsubishi WS-65611 65" Rear Projection...
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
TV is turn on for 3 seconds and then shuts off.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Mitsubishi WS-55908 55" Rear Projection...
Hi, I have a WS-55908 Mitsubishi tv, I turn it on
Do the self check this set has--when you turn on and power light comes on and then goes off:
On the front of the set press both the Menu and Input (device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light will then blink a two digit error code--the most common is 2 blinks, a pause and 2 blinks---it will repeat it several times.
Let me know what you find and I will tell you what it means---based on your description I bet you get 2,2 error code.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi VS-55707 TV powers on for about 1 second then powers off. I have replaced the convergence IC's, but still get the error code 22. Are there any resistors that I should be double checking?
THERE ARE 2 CURRENT LIMITERS 1 OHM OR SOLIDER IN FUSES FOR + & - SUPPLY THEY FEED THE CONVERGENCE IC'S YOU NEED TO VERIFY YOU HAVE YOUR POWER SOURCE TO THESE. ALSO A LOSS OF VERTICAL DEFLECTION WILL CAUSE THIS.
Dec 22, 2009 | Mitsubishi VS-55707 TV
Mitsubishi WS-55908 Rear Projection. Doesen't Stay on.
have you tried to access the self diagnosis feature by holding the menu and device/input buttons on the set both in together for five seconds to see if the led will blink a two digit code such as two blinks pause two blinks for a 22 error? Try that and let me know the blink code and i can assist you.
May 21, 2009 | Televison & Video
Code 22, will not power up.
i found you a manual :)
http://www.mitsubishi-tv.com/support.html
from here select
CRT televisions, year:2003, then your model, and click pdf :)
Nov 19, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
My ws-55908 just turned off the other day and does not turn back on.
the main power supply has gone out it may not be worth the 4to5 hundred to repair it
Jun 21, 2008 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi WS-55908 55" Rear Projection Television Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
