Question about LG WM-2277HW Front Load Washer
Willnot spin, error code 6e
Lg wm2277h will not spin. displays 6e error code
Lg wf-t851 will not spin. displays 6e error code
Posted on May 24, 2009
6E
if top loader then E6 is clutch error
Aug 28, 2014 | LG Washing Machines
It gives me an error code either 6E or bE
BE OR 6E IS belt broken check your belt if its ok you will have to check pc board and wireing
Apr 03, 2014 | LG IS 250 Dryers
Code error "6E" on Dryer LG td-c70210e
ok so 6E means that your thermistor is out of range
Nov 23, 2012 | Dryers
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
I have an lg wm2277h washing machine, i keep getting LE error at display how can i fix this?
This is caused by a bad Hall Sensor. when it is bad it tells the computer that there is too much load on the motor, therefore giving you the LE code, otherwise known as a (Locked Rotor Error). It is cheap and fairly easy to replace, the part can be ordered at Sears Parts, using your model number. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 20, 2010 | LG WM2277H Front Load Washer
LE error after full cycle toward end of wash it comes up with an error. not sure if it LE or upside down F E? Anyone have this prob?
LE toward the end of cycle probably means you had a bulky load which you tried to spin out at the high spin speed setting. Use a low spin speed with bulky loads. For this load now, just put power on and without selecting a cycle, push the spin speed selector button until a low speed comes up (should be about a 14 minute display) then push start to do a pump and spin only cycle.
Sep 25, 2010 | LG WM2277H Front Load Washer
I have an error code oe displaying on my washer and washer will not spin , can you tell me where to start to fix the problem? thanks dwayne
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | LG WM2277H Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
LG TROMM - Won't spin - Spin button - blinking
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 10, 2009 | LG WM2277H Stainless Steel Front Load...
LG WM-2277HW Front Load Washer Logo
1,249 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
