Question about Estate TAWX700JQ Top Load Washer
Filled with water but wont turn on
Just moved. Never had a problem until now.
    President:
  • 3,113 Answers
Push down on lid to activate switch. The switch striker on lid is not pushing down the switch so it can turn on. You may bend the lid where the striker is attached to over to the right a little or trim door bumpers.
Posted on May 23, 2009
  • honeymokey
    honeymokey May 23, 2009
  • honeymokey
When filling, the toilet makes a loud noise like a water buffalo dying and wont stop until I turn off the valve. whats the deal?
That miniature water buffalo may be living inside a clogged fill valve. It may be necessary to replace the valve to regain peace and quiet. If you do replace the fill valve, be sure to flush the water line first in case any debris is lingering.
Jan 09, 2017 | Home
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Cycle wont move on withhotpoint 220
check the heater once its filled it will stay in wash until it heats to the correct temperature so if the heater has failed it will stick in programme
Feb 27, 2014 | Hotpoint Washing Machines
Machine says "fill water tank"
look at the magnet (left, closer to you side, inside the water tank). It might be stuck. try bumping it slightly or insert a toothpick in the hole and slightly move it up-down. It might help.
Jan 06, 2011 | Spidem Trevi Digital Plus Coffee Maker
How can I demineralize my rowenta iron? I use carbon filtered water in it. The last time I used it white stuff came out of the steam ports and it sounded like there was sediment inside when I moved the...
Fill the resevoir with a 25% vinegar to water solution & turn on the iron until it steams. Allow to cool and empty resevoir then rinse with clean water. Fill up resevoir and & turn on the iron until it steams again. Cool, empty & rinse again. DONE!
Only use distilled or reverse osmosis water in your iron. This will reduce mineral build up.
Nov 13, 2010 | Rowenta Irons
Water leak at back of ice maker ,made big ice ball at rear of tray then ran out on floor. Turned off water ,cleaned out ice now wont do anything .. Tray wont fill , rack dosent move.Was making ice good...
sounds like you have a bad water valve solenoid. check the ½" diameter fill tube that feeds the water into the fillcup of the icemaker, you may have to remove the icemaker to see inside. is this tube frozen with ice? if it is, you have a bad solenoid.
Feb 15, 2010 | Refrigerators
Washer wont fill up, keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer fills wont agitate or spin
supposed to be a problem only with water level switch.
hhhmmmnnn...
try checking the hose that goes from the bottom end to the pressure switch. if there is a hole or a crack or anything loose on the connection. if the pressure won't build up on the water level switch, it wont transfer the contacts to start agitating.
test the water level switch by pulling the hose from the drum end and blow unto it until you hear a click on the water level switch. this should turn your agitator so please be careful and watch out for parts moving rapidly.
tnx 4 using fixya,
drcool
Oct 28, 2008 | Maytag Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Estate TAWX700JQ Top Load Washer Logo
64 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
