Question about Whirlpool ED5FTGX Side by Side Refrigerator
Icemaker quit making ice cubes.
I lost my owners manual.I have a side by side whirlpool.Also I can't find a model # on the refrigerator.
  • Anonymous May 24, 2009
    It emptied last batch & never refilled.
  • Whirlpool Master
  • 4,654 Answers
Can you tell me if the ice maker has ice in it from the time that it did work. Or did it empty the last batch and never refill. It's possible I can help, Sea Breeze
Posted on May 24, 2009
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
Icemaker is not making ice cubes. fridge is 3 months old.
Well if your ice cube bucket is on the freezer door it self then it could be anything from the optics system to a bad icemaker to a water valve issue...if its located on the side freezer wall. the water valve could be bad or the i/m module/icemaker
Jan 22, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool icemaker quit
I/M itself is most likely bad. Is there ice in the mold or is it dry?
Nov 28, 2008 | Whirlpool ED2FHEXN Side by Side...
The icemaker makes ice, but then it fills up with water and
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the phone number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 11, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker
That means that the solenoid that controls the ice maker is defective and must be replaced with a new one.
Use the number listed on the owner manual if you want to call a technician.
Jul 23, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED5FTGX Side by Side Refrigerator Logo
157 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
