Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge side by side dispenses ice but not water. water button clicks but does not humm I would like to know how long it takes to thaw a frozen line to the water dispenser?
  • 1,543 Answers
Remove lower grill and disconnect the water line going through the freezer door hinge. Usually it is a push lock fitting, which requires you to push the ring on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X101073 water tube heater. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
Comment by MNTECH, posted on May 20, 2009 Sorry, didn't notice that I put an extra zero in the part number. It should be a WR49X10173
Posted on May 24, 2009
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE ice maker is working, but the water dispenser will not dispense water. I replaced the filter and the water dispenser did work for a few days and than quit. When I take the bottom grill off and take...
The line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . WR49X10173 , is the part number for the heater for the water dispensor , to keep this from happening again . Instructions come with the part .
Mar 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
Mar 02, 2010 | GE GSH25JFT
Ice dispensor not working
Most likely reason water not dispensing out door 1) You can turn up the temp in the freezer to see if it thaws in a couple of days, 2) Turn on the dispenser light and leave it on, will thaw the line and keep it thawed, 3) the water tank is frozen in the fresh food side (you can defrost with a blow drier) 6) the fill valve went bad or plugged ( power to fill valve but not opening) ($50) 7) Micro switch went bad in the dispenser for the water side 8) Door switch bad 9) Install a heater kit to thaw the line and it will keep it thawed ($35) PN#1381601 10) You can replace the whole door if insulation gone bad in door ( $500 to $800) 11) a broken wire to the fill valve ( no power to fill valve ) 12) with GE refrigerator bad dispenser boards or control boards ($400 and $150) 13) plugged, faulty or incorrectly installed water filter let me know more about you problem and I can help..
Sep 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
No water from door dispenser
BAD WATER VALVE OR CHECK FOR CLOGGED FILTER
Jun 18, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
May 23, 2009 | GE Profile PSI23NCR Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Dec 13, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
211 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
