Question about D-Link AirPlus DI-524 Wireless Router
There's no output signal on my router when i connect my modem to it and the out is to my PC, it says no network connection
Theres no output, i mean no internet connection when i connect my modem to my router and the out is to my PC
  • D-Link Master
  • 4,338 Answers
Connect the Cable modem to the router's Internet/WAN port, then connect the PC to any one of the router's ports.
Reset the D-Link router:
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds. Then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 23, 2009
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
I have a full signal on my pc via DIR-412 but no internet connection
Is this the first time you set your router? Make sure that the cable from your modem to your router is connected properly. You can also try connecting the modem directly into your PC just to make sure your modem is connected to the internet. If it is working without the router, reset your router then connect the modem again to your router.
Sep 15, 2011 | D-Link Network Router DIR-412 Mobile 3GB...
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
How to set up the wireless internet connect on my laptop to this new SBG901 modem?
Short answer: YOU DO NOT.
The cable-modem just converts from the cable-company's signals to/from Ethernet signals.
You use an Ethernet cable to connect the output from the cable-modem to the 'WAN' (or 'Internet') port on a router with wireless capabilities. Then, you configure the router to create your own wireless network, with:
* an SSID ("network name")
* encryption level (use: WPA)
* a password for your network
Then, your wireless device can cite the SSID/password to authenticate to the router.
Feb 24, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
When I connect my router i lose internet connection, even though my modem still shows connectivity. I have followed the instructions to connect the router to my computer and the modem to the router. Any...
firstly, connect your modem to the router and your pc to the router. Next, reboot your PC. try to access the net. If you now can, great. If not, you may need to switch on DHCP and NAT in your modem. DHCP means Dynamic Host Control Protocol and NAT means Network Address Translation. Both of these services are required to allow your PC to access the net through your router. I am assuming that you have a modem and a separate network switch. If you have a modem and the router is another modem with a network switch built in, then you cannot use them both at the same time. If the router has a modem built in, remove your old modem and set up the router according to its manual. Entering your ISP login details either through the routers setup software or through the routers own browser page. The manual for the router will tell you how to do this. If the router is a netwrok switch, then you will need to log into your modems browser page and turn on DHCP and NAT. Then save and reboot the modem and reboot your PC. Once everything has rebooted, go into your control panel, Network connections and check that a valid connection has been made. If yes, then access the net using your browser. If no, try the Network Setup Wizard to repair or replace the existing setup with an updated one. Just run through the wizard choosing the correct or most appropriate options from the menu's..
Oct 31, 2009 | Linksys WRT54G2 Wireless Router
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Belkin Wireless Modem Router problem
well, first of all the i also have the N1 belkin wireless modem router, in order for it to connect, there has to be a wireless connection in your area for you to connect to, if any of your neighbors so have wireless you can connect to their network, but if you are not getting a conection that means no one around you has wireless or lan, the belkin wireless is not a internet provider it just extends the distance of your internal wireless. some networks may be secured as well, sometimes you can only connect to unsecured networks unless you have the name and passcode for the secured network.
May 28, 2008 | Computers & Internet
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
D-Link AirPlus DI-524 Wireless Router Logo
188 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
