Question about Sony SDM-HS73 17" Flat Panel LCD Monitor
My monitor wont stay on.
When I turn on my monitor it stays on for about thirty seconds and then shuts off. Even after adjusting the plugs and changing the plugs it doesn't work.
  • Frank Zhang
    Frank Zhang May 11, 2010
    is there any show on screen within 30s from PC VGA?
  • 31 Answers
May sound wierd, but Its windows, try going into safe mode, and changing the screen size, (1024 x 768) sometimes, it gets put on a size that doesnt fit your pc/screen, so it turns off.. Like I said, go into safe mode, and change it around and reboot untill it works.. I had that issue once.
Posted on May 23, 2009
Monitor wont stay on
turn off power saving mode on the monitor
Apr 10, 2016 | Hanns.G 22"" hi221dpb dvi widescreen lcd...
Monitor won't stay on
More likely to have problem in the power supply due to bad caps, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 01, 2010 | Envision EN9410 19" Flat Panel LCD Monitor
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
My tv shuts off all by itself
sounds like the power supply is going bad
Jul 20, 2009 | Philips 32RF50S 32" TV
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor will not stay on
I am having the same issue. Stays on for 2 seconds then goes black. If I find a solution I'll let you know.
Apr 07, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Television shuts off after about thirty seconds
You definitely need the lamp. If you can provide the make and model # i can probably tell you which lamp you need.
Mar 29, 2009 | Televison & Video
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Feb 03, 2009 | Dell E770 Monitor
Monitor problem
erickalin - it sounds like your computer might have shut down and failed to come back up again. If you have access to another monitor, try hooking it up to your computer instead of the one you normally use (that won't stay on). If the second monitor won't stay on, the problem is your computer. You might have to take it to your local computer geek or computer store to get serviced. If your computer DOES work with the second monitor, you might need to have your monitor serviced or replaced. Good luck!
supposed2b, I think you have the same problem, although your computer doesn't even sound like it's powering up. Your power supply might be faulty or an internal component (CPU or memory most likely) of your computer has died. Double check your power connections and ensure that when you press the power button you hear the computer start up and the light on the front comes on (hopefully green or blue, but not yellow or red). Again, you might need to take your computer in for service.
Jun 10, 2008 | Computers & Internet
Sony SDM-HS73 17" Flat Panel LCD Monitor Logo
325 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
