Question about Acer Computers & Internet
Ac adaptor won't fit into any ports
The ac adaptor won't fit into any of the holes (ports)
  • mrninja
    mrninja May 11, 2010
    we need alot more info....what are you trying to plug in? what type of connector is at the other end of the AC adapter? Also if its an AC (alternating current) thats the 2-or3 prog plug that plugs into a wall outlet-the other end better not plug into the PC or you will light up the sky like the Fourth of July
    Sergeant:
    Champion:
  • 212 Answers
You need to go get the right adapter. The one You have probably isn't the right one.
Posted on May 23, 2009
I have a Vivitar Vivicam 6320. There was an AC adaptor but that has been mislaid. I would like to use a generic adaptor. Any help would be appreciated.
There are universal adapters that have several common voltages with a selector switch. They come with different style interchangeable plug ends, so one of them will fit your camera.
Original Power Powerline 1300 mA Universal AC Adapter One similar to this will work well for you.
Dec 06, 2016 | Vivitar ViviCam 6320 Digital Camera
How to vacum my spa with pool maintenance kit
if you have the intex kit , it comes with instuctions but hers it ina nut shell , find adaptor plate that fits inside skimmer (flat thing with hose port in middle) assemble sustion head and handle with hose attached and drop into pool (keep handle out) fill hose full so it sort of sinks (no air gaps) snake carefully end of hose over to skimmer (pump running normal) fit plate into skimmer quickly snake hose thru skimmer hole and fit to plate adaptor on hose port , wait a few minutes if flow continues out pump dishcharge then your good to go if not dissasemble and start over , but let filter pick up prime again 1st , do not lift head out of water even to get big stuff off pickup do it in the pool under water
Jul 23, 2014 | Intex Above Ground Swimming Pool Skimmer...
Can't find the LOW PRESSURE port on a 2004 Dodge Durango to charge the AC???
cannot say for sure as i have never seen one of these vehicles but some vehicles do not have a low pressure port as such ,you need a special adaptor as it only uses a high pressure fitting on the low pressure pipe ,confusing i know but lots of new europeon vehicles only have the one fitting so ask at dealer to be sure
Aug 20, 2011 | 2004 Dodge Durango
Netbook is dead, won't operate on AC power,is the adaptor dead?
A good chance the ac is bad, try getting another one, the battery may be bad as well, or the charging port on the computer may be bad as well.
Aug 10, 2011 | Gateway LT2021u Netbook
When i push the power butten, the indicator light flickers, then nothinghappens
Firstly remove the battery and disconnect the A.C adaptor. Press and hold the power button for 30sec and then reconnect them back and check.
Check the port where u connect the A.C adaptor pin if the light is glowing then need to reseat the RAM and the Hard drive of the laptop (Compartments located at the bottom of the laptop)
If still not comming on then Hardware issue take it to local store.
But if the port where u connect the A.C adaptor doesnt have light then
1. check with different wall outlet
2. check if the adaptor is getting warm or not if not then replace it.
3. If yes then better check with different ac adaptor
Mar 31, 2010 | Acer Aspire 5100 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Battery won,t charge
the price of KLIC7001 $29.00 try to purchase the battery at wallmart target or at kodak.com/go/shop.,
how do you charged your camera USB cable or AC adaptor? if USB cable make sure that the Cable is working fined and the USB port of a computer is not defective., If the AC adaptor., try to clean the 3 metal contacts of your KLIC7001 using clean dry cloth, then charge it again. if its failed., try to test first the camera itself using different KLIC7001 if its not charging it means the problem is on the camera not the battery
Nov 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Power Supply cord from ac adapter to wall plug needed
Any electronics store should have one, they are all the same. try radioshack
Jun 19, 2009 | Western Digital My Book Essential Edition...
Why won't my pc read the mini disc thing in my Panasonic VDR-D150EF-S?
Yes you need to finalise the discs before you can use them in another player, even a computer.
Behind your battery there is normally a plug hole for your power adaptor to connect to so you can transfer movies etc on power rather then on battery.
Apr 16, 2008 | Panasonic VDR-D150EF-S DVD Camcorder
AC Adaptor
Is the AC adaptor model AC Power Adapter: AC-3VX? If so it should fit, if not, have it replaced to where you bought it from...
Dec 09, 2007 | Fuji FinePix A500 Digital Camera
Computers & Internet Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
