Question about Dell 926 All-In-One InkJet Printer
Unable to print on printer Dell 926 -test page prints ok
Test page prints ok but unable to print from word, excel or email- printer sounds as if printing but blank-have tried uninstalling and re-installing but same problem
Although the black ink cartridges showed sufficient ink, it was actually empty - I discovered this when I changed the font color from black to red and the prints were fine.
Posted on May 26, 2009
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on May 24, 2009
My printer prints blank pages
do you have to copies of the same printer in control panels printer menu? dell printer
Nov 30, 2011 | Dell 926 All-In-One InkJet Printer
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
I have dell 926 all in 1 printer,a dell inspiron1525 laptop i have uninstall/install the drivers from dell 3 times,print jobs Que but not print via laptop,not even a test page
Hi
Did you use the printer before that is connected to your laptop and prints fine or you are setting up the printer but unable to set up?
Before that check that all the cable connection are connected. Remove and connect it again, then when setting up the printer, check if it is reconized by your laptop by adding and setting up the printer once more.
Check also the printer's compatibility with the operating system? and install the correct driver?
Check also the USB cable and make sure you are using a USB cable port?
Please post comment for more help. Regards
Mar 31, 2011 | Dell 962 Photo All-In-One InkJet Printer
Have trouble with printer, printing the test page over and over and can't print nothing else.
Please,
Set back your printer manually from control panel then test again your printer. Re install the printer driver if necessary
Jan 09, 2011 | Dell 926 All-In-One InkJet Printer
I have a Dell 926 with Error code of 1203 and unable to print
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
PLease rate me 4 thumbs
GOod Luck!!
Jul 14, 2010 | Dell 924 All-in-One InkJet Printer
Printer not printing documents in que
my printer hp psc1315xi all in one printer copier, scanner will not print any documents, not even a test print, there is also a doucument in it that am not able to delet from the printer
Jan 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Printing web pages
sounds like a settings issue with your browser to me.
Jul 19, 2008 | Dell 3110cn Laser Printer
This document failed to print
Move the mouse to the printer icon, press the right mouse button and, select properties. Press the print test page button.
Jun 14, 2008 | Microsoft Windows XP Home Edition
Dell 926 All-In-One InkJet Printer Logo
367 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
