Question about Sora MiVoice 1418SU Handheld Digital Voice Recorder
Device not recognized
I plugged my 1418SU into the computer and the device was not recognized (it was eecognized about 2 years ago when I first used it). I checked with my device manager and it did show
* USB Flash Memory Controller Driver: (6002).
I right-clicked the unplug-eject hardware on the tool bar and the device also shows.
I unplugged the USB cabe and it did complain about "Unsafe Removal of Device." All these point to the fact that the device seemed to be recognized.
BUT, I clicked "My computer" and I just did not find the device in one of the removable drives.
I have a Kingston Data Traveler 8GB USB Flash Drive which I bought 4weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
The thumb drive might have some fault.
Plug it in other OS mainly windows XP and Linux.
If still same problem persists after tried in Linux, problem is with pen drive.
You can ask for a replacement from the dealer as it has guarantee for 5years.
Nov 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a Kingston Data Traveler 2GB USB Flash Drive which I bought 2weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
We have all had it, yesterday it was fine now it says it doesn't recognise ya USB device.. AARrrgg. Well there are various way to try to fix. Now providing your USB aint Kaput then this works like 99 outa a hundered.Simply Remove and reinstall all USB controllersTo remove and reinstall all USB controllers, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
  2. Click the Hardware tab.
  3. Click the Device Manager button.
  4. Expand Universal Serial Bus controllers.
  5. Right-click every device under the Universal Serial Bus controllersnode, and then click Uninstall to remove them one at a time.
  6. Restart the computer, and "Windows" will then automatically reinstall the USB controllers.
  7. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Remember with USB devices. FIRST, install software/drivers, then insert USB device SECOND.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Samsung YP-U3 is not recognized by computer
it is not appering in my copmuters but it is charging.
Jul 23, 2009 | Samsung YP-U3 MP3 Player
My computer wont recognize my USB
Try the following steps:
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
If that doesn't work, then you may download and install the Sansa Firmware Updater and update to the latest firmware.
Jun 04, 2009 | SanDisk Sansa e260 MP3 Player
Hard drive is not recognize by the computer
have you tried using it on another computer? if its a plug and play device and it works on another computer, the problem may be with your computer. you have to first try this device on another computer to see if it works or not.
Jun 11, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
My Sansa C200 is no longer recognized by my computer.
What I would recommend you to do is to make sure that your device is under MTP mode instead of MSC...to do that go under menu,setting, usb and then there should the two mode listed there...then you want to plug your device in the back of your computer..not in the front..tghat is very important....once you do that..open up your windows media player...click on your start thee sync panel..if your device is recognize properly it will be showing there on the right side..and if its not listed properly, it will say connect a device..if thats the case..click on your start menu right click on computer and then click on propetties, click under hardware and then device manager..your device should be showing there...check under disk drives to see if your device is showing there and if it doesnt you want to right click and hit uninstall...we dont want your device to be under disk drive ..we want it to be under windows portable device...once you uninstall it...go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Apr 20, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
GSA-2166D recognized by computer but does not recogniz media?
Try removing the device from device manager, then reboot. Windows should then re-detect the device and re-install the drivers for it. If that doesn't work, try the device on another computer. If it still doesn't work, it's probably defective.
Jan 27, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
USB device not recognized
corruption.
not fixable.
device can not tell os what it is. that is the most basic of functions.
without id, it can not set configuration needed to access data.
probably already lost data anyway.
replace is about the only option.
sorry for the news
good luck
mark
Dec 22, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Computer Won't Recognize Device
Try plugging your USB cable (attached to your player) into the computer before you turn the computer on and boot up . . . I had this same problem with a flash drive that the computer would not recognize if I plugged it into the computer while the computer was already on.
Aug 21, 2007 | Mpio FY500 MP3 Player
Sora MiVoice 1418SU Handheld Digital Voice Recorder Logo
37 people viewed this question
Top Sora Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sora Audio Player and Recorder Expert? Answer questions, earn points and help others
