Was is covered with lint extra rinses does not seem to remove
Lint problem does not seem to go away with extra rinses. Have cleaned the agitator
  • 62 Answers
I do not know how to clean it. It is called Fresh
The Fresh Air has a reminder on the LCD to Perform Cleaning. This reminder will display if the purifier runs for 30 days. When this reminder is displayed perform the following steps to clean your purifier.
1. Cleaning the Case:
Wipe the unit with a soft cloth dampened with water. Do not use chemicals or solvents. Vacuum the front and rear grills to remove any lint buildup.
2. To clean the lint screen, RCI cell and purification plate:
3. To remove the back cover:
Remove the plug from the back of the unit. Unscrew the screw above the plug socket on the back cover. To remove the back cover, press the back sides of the back cover to unlatch and tilt the bottom of the back cover to remove.
4. To remove the rear lint screen:
Remove the two thumbscrews holding the top of the lint screen. Remove the lint screen by pulling back the top of the screen, then lift it up and out.
5. Removing the RCI cell:
Remove the RCI cell connector by pressing the connector locking tabs. Pull the connector straight out to unplug.
Remove the RCI cell by removing the two thumbscrews. Slide the RCI cell down and out of the unit.
6. Cleaning the RCI Cell:
Remove the RCI cell and carefully vacuum accumulated lint. Do not wash the RCI cell. Damage from water may result.
7. Rear lint screen cleaning:
You have two options
  1. When visibly dirty, simply remove the rear lint screen from the unit and with a duster attachment on a vacuum, remove the heavy particulate.
  2. In addition to step 1, the filter can be washed with hot water (do not use soap). Allow to dry prior to reinstalling. Replace if damaged.
8. Cleaning the Purifier Plate:
Remove the plate from the card cage by grasping the middle edge nearest to you, and slowly pull it straight out. Clean with mixture of one part water and one part ammonia. Place plate and ammonia mixture in a dish and allow it to soak for no more than 10 minutes. Remove plate and scrub with a toothbrush. Rinse thoroughly and air dry for 24 hours or use a blow dryer to dry thoroughly.
After all parts have been cleaned and are thoroughly dry, reinstall components in reverse order. Turn the purifier on, and on the key pad, press the reminder Reset button to clear the Perform Cleaning message.
If this has been helpful, please rate this solution. Thanks
Jan 28, 2010 | Ecoquest Fresh Air Living Air Purifier
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
I just changed my black ink cartridge. Now, after
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 18, 2009 | Office Equipment & Supplies
My dryer is not as hot and taking much longer to dry the clothes. How do I fix this. I clean the lint trap after every load. I have a ge profile dryer about 5-6 years old.
Three main possibilities:
Either lint is clogging the airflow or a fuse is popped from overheating, or the heating element is broken..
You have to open up and clean out no matter what.
Unplug the unit.
Remove the lint screen and the two screws at the lint slide.
Use a putty knife to release and pry up the clips which hold down the top cover, tilt up the top cover.
Remove the two screws near the top which secure the front cover, tilt out and lift off of the two clips at bottom.
Release the belt tensioner and remove the drum.
Now you can completely vacuum out the entire cabinet. I know some persons who take a pressure washer to it (the motor seems to tolerate the wet treatment).
Remove the rear cover by removing the screws.
On the left (as you look at the rear) you will see a duct leading to the lint screen. Remove the screws and wiring harness (mark the wires). Lift it away and you will see the blower fan. It is invariably loaded with crud, coins, paperclips etc. Clean it out. If you must remove it turn it clockwise as a wrench holds the motor shaft stationary (there is a flat spot near the belt pulley).
Check the heating element. It should not be broken and read "closed" on an ohmmeter.
Clean all and reassemble after you have replaced any fuses.
Fuses should read "closed" or zero ohms. Some person test for bad fuses by temporarily connecting the two wires and then running the unit. If it only gets hot when you do this you should DEFINITELY replace the fuse.
Aug 02, 2009 | GE Dryers
It is taking 3 full cycles to dry my small loads on my Maytag Performa PYE2300AYW. I have cleaned lint tray and trap. I need to clean the lint from the inside of my dryer - How do I do this?
The main area that you have to clean is the pipe leading from the back of your dryer to outdoors. Pull your dryer away from the wall. Unplug it. Unfasten the vent pipe. Now look into the back of the dryer exhaust and remove any lint you see there then look into the vent pipe and remove any lint. Finally go outdoors and remove any lint you see in the pipe or the pipe grill/cover.
Jun 04, 2009 | Maytag PYE2300AY Electric Dryer
Lint sticks to the lint cover and lint filter.
Use a degreased such as goo gone, or an aerosol electric parts cleaner/degreaser. It may look gone, but there is still scum built up in those tiny little holes.
Dec 26, 2008 | Frigidaire GLEQ642A Electric Dryer
The lint is not being washed from machine. All dark clothing has lint residue. How can I rectify this problem please? Currently my husband using damp cloth has to wipe over black clothing extensively prior...
the self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
  • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
  •  no soap.
  • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
the lint filter may be defective since it has always had this problem, but its worth a try.
Jul 01, 2008 | Maytag Washing Machines
Lint on clothes
run a load with no clothes with hot water and a gallon or two of bleach.
do an extra rinse cycle a couple times to make sure the bleach is rinsed out completely.
Jun 26, 2008 | Washing Machines
Detergent doesn't seem to rinse out
common problem you may need to remove the spin bowl and clean them they get lint build up around the top hope this helps.
Mar 03, 2008 | Maytag Performa PAV2200
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
