Philips Magnavox 27MS343S 27" TV Logo
Posted on Oct 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cable cord pulled completely out of tv. how can i replace it.
Michael Borelli
Level 3:
  • Master 979 Answers
  • Posted on Oct 20, 2007
Michael Borelli
Master
Level 3:
Answers
979
Questions
Helped
328689
Points
1751
Not familiar with the term you're using. Do you mean the power cord?
Could a wire have broke off inside the back of my older model 50inch hitachi tv,with the bigger backside,when the cable cord was pulled out of the back, instead of unsqrewing it fromits connection? th
No. No wire should come out. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Loose hood cord 95' civic, first I had to push the little latch that makes the hood shut completely with a screw driver now it won't even open (the hood) I pulled on the cable with pliers but no...
Just perform some checks please,
  • try to pull the hood release lever with its cable tightly pulled towards you.
  • that may tighten the loose cable so a release can happen
  • then pull out the hood piece hard, so the lock would release.
  • trimming is not a good idea, because it would be hard to set it back into the assembly.
  • try this, good luck. vote it!!
1helpful
The yellow and white plug in to the the tv . i have to sat and pull down on them for the picture to stay on the tv
It sounds like you need to replace the cords completely. I think there's something faulty in the wiring. This does happen with any type of AV cords.
2answers
Audio video ports bent and a cable port completely pulled out
You will need to contact a regular tv repair shop and if he is authorized for your brand,that is a plus. He may say the whole board would need replaced,which will be un feasible.....he may be able to re attatc and solder the jacks back to gether. Either way that is where you start!
Mitsu. 60-inch VS-60609 Green Light goes out..tv goes off.
You are dealing with bad solder connections. The solution is to pull the board, put it under a magnifying glass and resolder all suspicious connections. before going too far with pulling the chassis, look over all the boards near the egde under the tubes. Be sure there is no liquid present, if there is give it up the set is toast. If not then continue on and place piece of plastic draped over the front of the left and middle boards to about 5 inches in towards the center just before putting the back on the set.
2answers
Split screen from DVD player, cable is fine no problem
It is not clear where you say input is from cable, do you mean the Scart input to your Sony TV? Do not use Progressive scan(p), as this is not interlaced. The normal TV requires an interlaced(i) picture of 50 half frames per second giving 25 complete pictures per second to reduce flicker. Some TVs and projectors and all monitors accept Progressive scan.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
