Question about Haier (HPE09XC6) Air Conditioner
For some reason my AC started making a clanging noise. Upon checking I found that the blades went flying off the fan. How can I fix this
For some reason my AC started making a clanging noise. Upon checking I found that the blades went flying off the fan. How can I fix this.
  • HANK MCNEIL May 11, 2010
    replace the blades!?
  • 20 Answers
Need a new fan blade. might want to check out your local wholesale parts store. make sure you take unit model # and s#
Posted on May 23, 2009
My Hampton Bay Victoria 70 in. French Beige Ceiling Fan has started to sway and make funny noise anything above a level 3
swaying fans are a symptom of out of balance. The blades have to be all at the same height to the ceiling or from the floor . It it was ok before but just started this when the noise started then it may be failing bearing in the fan.
with most fans that means a new one but take it to an appliance shop as it may be repairable.
bearings will be from a bearing supply shop
Apr 01, 2015 | Hampton Bay Dryers
Need to purchase fly wheel for Hampton Bay five blade fan 1988 model. Where could I?
I didn't know a low end fan had a flywheel. Can you send or post a pic? fanman9952@aol.com
Oct 17, 2014 | Dryers
What's the CHEAPEST fix for my loud ac compressor?
I have a2004 mustang with a 3.9 making the same noise,and the shop replaced the AC compressor and all belt tensioners. I found that the noise is the timing chain tensionors .
Oct 28, 2012 | 2002 Ford Mustang
I hit a stone and now the engine clater
THE MOWER MIGHT BE OUT OF TIME. REPLACE THE BLADE. CHECK THE WOODRUFF KEY INBETWEEN THE PROPELLAR SHAFT. IF ITS BENT REPLACE IT. ALSO CHECK THE TOP END OF THE PROP SHAFT FOR ANY MISS ALIGNMENT. IT SOUNDS LIKE THE ROCK IMPACT MADE SOMETHING LOOSE IN THERE>
Jul 25, 2012 | Poulan Pro " Pro" Self Propelled Mower
Why is my 1987 300e Mercedes making a loud clanging noise at start up?
I would think the honeycomb ceramic "Brick" inside the Catalytic Converter has broken up, makes a terrible rattling when this happens.
Nov 26, 2011 | 1987 Mercedes-Benz 300-Class
The fan on this AC broke for some reason. The blades flew out of the AC. Can this be fixed? If so, how? How much for new fan?
outdoor fan if it hit your condenser coil your toast, if its indoor blower (squirrel cage) lets say about $500- $700 if you have pro do your work. have a pro do it NATE certified
May 23, 2009 | Heating & Cooling
Whirlpool Gold Fridge w/ freezer on top. LOUD banging noises.
I think the banging means the compressor is shot. (more like a load "clunk"). I had the same noise on a dehumifier.) I dont' think replacing a compressor is a DIY, and doubt it is economically efficient. But I leave that to the specialists to comment on. Check Craig's List in your area - you can get a good deal for a few hundred bucks.
Also, the "clanging noices" is probably the fan blades for the air circulator that moves cold air from the freezer to refrig compartment. Check the online manual for your model (exploded parts view) to see where it is located and if it is readily accessible by taking out a few screws inside the refrigerator. Might be more than one fan - open the door when it happens and see if you can locate where the noice is coming from. This is a plausible DIY - I did it only my old fridge - replacement parts were cheap. But you might even be able to just reallign the fan blades so they don't clang.
Oct 26, 2008 | Refrigerators
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
GE GSL25JFR Freezer fan noise.
You are correct in believing the fan is going to be a problem. The evaporator fans inside the freezer compartment are common at going bad. I believe it is due to the extreme temperature and moisture conditions inside the application. The noise is the stator or bearing equivalent going out, the speed should remain constant. It may eventually make a screeching noise upon start up, or just lock up completely. The good news is replacements are relatively cheap and easy to find. If you do replace it yourself, make sure the fan blades are blowing in the right direction. If possible, remove the old one and bring it with you to the local appliance parts supplier and he should be able to help you get the right one, it will probably be a kit of some sort with multiple mounting brackets, screws, and maybe even a couple of blades. don't let this intimidate you. Most of this you will not use.
Dec 17, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Haier (HPE09XC6) Air Conditioner Logo
314 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
