outdoor fan if it hit your condenser coil your toast, if its indoor blower (squirrel cage) lets say about $500- $700 if you have pro do your work. have a pro do it NATE certified
I live in Phoenix Arizona and yes this is a heat pump. We really have no use for heat strips, but I...
(More)
I live in Phoenix Arizona and yes this is a heat pump. We really have no use for heat strips, but I have read that is an option. This situation only happens when the outside temps are below 40. The unit kicks off for about 2 minutes and then tries to restart and when it does start blowing hot air again it's not very hot. This process usually drops indoor temps about 1 degree, but if you are sitting next to a vent it's pretty cold. I have never seen any moisture outside in the unit or ice. I will have to check tomorrow morning o the compressor temp and let you know. I have done some reading and I beleive it's either low on frion or going into superheat mode. This unit was purchased in 2007 new and has done this since day 1.
I have a Friedrich Split system model MW18Y3Y w heat. When I put on the heat, I am getting a trouble...
(More)
I have a Friedrich Split system model MW18Y3Y w heat. When I put on the heat, I am getting a trouble code of 5 flashing operation/timer and than a single timer flash. What could be the problem?
