Question about Kenmore 57029 Side by Side Refrigerator
Not cold I just got a house will all Kenmore appliances. The refrigerator was manufactured in Oct 2005. Side by Side, with water & ice in the door. Neither the frig nor the freezer are getting cold. The very bottom basket in the freezer gets ice cold, the vasket above that gets frig cold. Everything else is warm. We've tried unplugging it, to see if it'll reset something. Any ideas?
  • 62 Answers
Hello
I am also having a same problem what i will suggest you youcan see the bucket at the back side of the fridge,switch off ur fridge and turn out that bucket and then turned it back,if it is also not work then the wire is coming to ur fridgger check that wire by tester that the current is coming to that wire or not
This will help you
Thanks & Regards
Posted on May 23, 2009
Moved 9 year old kenmore to friends house just replaced ice maker. lights come on but refrigerator is not getting cold water is running ok but is warm
Is the freezer getting cold?
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
Kenmore Galaxy Ice Maker Not Making Ice
Sounds like you have a bad water valve. It will have a dual water valve on the back where the water connects to the unit. You can take the wire plugs and swap them around. Then push the water in the door leaver. hold it for around 4 sec. Then see if the ice tray has water in it. If it does, you have a bad valve. If not you ice make is bad, turned off or the freezer is not cold enough to operate. ( It has to be 5degrees or lower before the ice maker will try to operate)
Please rate this solution if it helps. Thanks
Aug 19, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker stopped working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker stopped working???
water valve or icemaker or make sure freezer is freezing check see if you have frost build up
Apr 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
My ice and water dispenser is leaking
I am not an expert on refrigerators, but generally you hook a 1/4" (copper or plastic) line to a solenoid valve to the back of your refrigerator, which you then hooks up to a filter, which then ties into an existing compression fitting, or saddle tap on a cold water line (usually on the kitchen sink). Some refrigerators have a place for a filter to fit which runs to the cold water, and not an exposed rear solenoid.
Sep 27, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 57029 Side by Side Refrigerator Logo
158 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
