Question about Panasonic DMR-ES35VS
Panasonic DMR-ES35V Remote Not Working
My remote controls the TV, but not the DVD (it's the DVD remote that came with DMR-ES35V). The settings on p 19 of the manual do not work because it requires pressing the "function" button...but none of the buttons on the remote work except for the top right corner which controls the TV...all of those work just fine.
I think the remote needs to be reset, but is there another way to reset it besides using the buttons on the remote? Some switch somewhere? A "reset the remote" code? A magnet? Hammer?
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
SOURCE: Panasonic Dmr es35v VCR/dvd recorder 'Set 1' problem
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Feb 19, 2009
Bati99
  • 88 Answers
SOURCE: panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Posted on Apr 19, 2009
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
nandosnut
  • 112 Answers
SOURCE: Remote control does not work, Model DMR-ES15
Press ENTER and the number shown on the unit (SET 1, 2 or 3) together on the remote control for at least two seconds to restore control.
Posted on Apr 24, 2009
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR-ES35VS: How do I connect my Panasonic DMR-ES35V through a ...
Put the main aerial into the set top box,then take a male to female fly lead and connect it to your panasonic,then take another fly lead from the panasonic into the tv.If you have two scart sockets on each unit and the tv you can connect one into the tv from the box and one from the panasonic into the tv,then you can connect the box to the panasonic so you could record from the box.
May 05, 2010 | Panasonic DMR-ES35VS
Feb 10, 2009 | Panasonic DMRES15 DVD Recorder
Remote doesn't work for DVD Recorder
It is now working. The DVD is below a Panasonic TV. We blocked the tv remote sensor and the DVD remote started working. We have unblocked the tv sensor and the dvd remote is still working. I'm not sure what was wrong or how exactly we fixed it.
Jan 28, 2009 | Televison & Video
Remote control doesn't work
Maby the IR codes are not compatible with the DVD recorder
Nov 25, 2008 | JVC XV-N320 DVD Player
My panasonic remote won't work. the lcd on the dvd shows set 1 everytime I click on it
I have had this happen nore than once. If you press the 1 button and hold it down. At same time press and hold the enter button for 2 or more seconds. Your remote will now be set to the system. Some models have a device code of 2 or 3. If your not sure what your device code is start with #1 device code.
Oct 13, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic dmr-es35v
sources of light?
Jul 29, 2008 | Panasonic DMR-ES35VS
Re: Panasonic Remote Control for DMR-ES35V
All you have to do is unplug the power cord from the unit, wait 10 seconds, and plug it back in. The reboot will make your remote work again. Actually, it is the UNIT that is faulty, not your remote.
Jun 25, 2008 | Panasonic DMR-ES35VS
Need help
I have the same model, i pressed Function key(on remote), enter, using up and down arrow keys, select Setup, Remote control code, press 1,2 or 3, then enter. The code on the unit has been set. You must use the same code for the remote control by pressing enter and hold for about 2 seconds at the same time pressing corresponding 1,2 or 3 you selected for unit. This makes the unit and remote compatible with each other. you only change this code if you have other panasonic products that respond to this same remote control. hope that helps.
Jun 14, 2008 | Televison & Video
Panasonic DMR-ES35VS Logo
513 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
