Question about Toshiba Satellite P25-S607 Notebook
HAD DC JACK REPLACED
WILL NOT START UP BY D/C ONLY WITH A CHARGE BATTERY
    President:
  • 2,992 Answers
I suspect that whoever replaced the DC jack didn't repair all the problem and the power doesn't get onto the motherboard. It's pretty easy to damage circuit traces when trying to replace the jack, or to overlook other damage caused by the jack going bad. You'll need to take the computer back to whoever worked on it and have it checked over again. I hope they provide some kind of warranty for their work.
Posted on May 23, 2009
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Dell 910 mini will not recognise any battery and will not recharge
You may have a loose DC jack:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
No power! power cord is good, but when inserted in the charging jack(laptop) the inside is loose and no charge is being sent to the battery. How do I replace the inside thing so power can be sent to the...
Here below is a guide about how to repair laptop DC jack, may it will help.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Jan 20, 2011 | Balance Computers & Internet
The battery will not charge if it runs down
HI there,
When a laptop/netbook will run on the A/C Adapter but the battery won't charge, there are only 3 things that can be wrong.
1. The battery is dead (replace the battery)
2. The A/C adapter's charging system is not functioning but the power function is. (replace the A/C adapter)
3. The DC power jack which is where the adapter plugs into the laptop is partially failing, providing power but no charging. (replace the DC jack)
Try to find a friend with an adapter/charger that fits your netbook and see what happens with that first. If that doesn't work, try to find someone whose Netbook takes the same battery and test if yours will charge in their laptop. After that, if your battery's not dead and you have a working charger, it's the DC jack and that costs about 80 to 100 to be replaced. They have to take apart the netbook, remove the jack and solder on a new one.
Good Luck
Marcus
Sep 14, 2010 | ASUS Eee PC 1000HE Netbook
I plug my ac adapter in my laptop usually when you charge it turns the battery light in red then after few seconds turns to green! do you think the charge is not working?
Hello my friend this looks like a battery problem or a bad connection between DC-IN power jack on the system board,first try to wiggle the power cord and if power LED and battery charge LED start flickering then is the DC-IN power jack`s problem ,if its not is battery problem and you should change the battery
I'm waiting for your response
Good luck my friend:)
Jan 27, 2010 | Acer Aspire 4520-5950 Laptop
Motherboard or DC Jack Problem???
i agree with your logic and think its a good idea to get the jack soldered to the the motherboard before anything else is replaced and would hardly cost anything too
Jul 26, 2009 | Computers & Internet
My PSP won't hold its charge anymore. We tried a new battery and it still won't charge well. Is it possible it's the charging mechanism inside the PSP? Is that easily replaceable?
Sounds like the dc jack is bad in the psp. From a place like this you can order a new psp dc jack:
http://www.portatronics.com/product_info.php?info=p422_PSP-DC-In-Jack.html
This site shows you how to open up the psp:
http://forums.afterdawn.com/thread_view.cfm/370436
Its cheap to get the dc jack the time consuming part is taking it apart and taking out the old one and putting in the new one.
If you do all of this and the known good battery still won't chage then that means the board is bad and would need to be replaced.
Jul 04, 2009 | Sony PlayStation Portable (PSP) Console
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Camcorder won't charge up
Its problem of DC-IN jack where you hook ac charger. This jack needs to be replaced.
Let me know exact model of camcorder to provide you part number of DC-In jack.
Jan 17, 2009 | Sony Handycam DCR-HC24E Mini DV Digital...
No power at all for my Dell Latitude D505
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
Nov 19, 2008 | Dell Latitude D505 Notebook
Toshiba Satellite P25-S607 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
