Question about Sony DAV-C770 System
PROTECTION MODE MY PLAYER IS IN PROTECTION MODE. IT WILL NOT ALLOW ME TO OPEN MY PLAYER OR PLAY A DVD. THERE IS POWER AND IT TURNS ON. AND THEN THE LCD SCREEN SAYS PROTECTION..AND THEN TURNS IT SELF OFF AGAIN. I CAN'T FIND MY MANUAL TO THIS DVD PLAYER
  • 5 more comments
  • Anonymous Dec 09, 2007
    I Have the same problem.
  • Anonymous Dec 27, 2007
    Same problem with my set
  • fireman_bob Dec 30, 2007
    Same problem with mine too. Speakers are disconnected and it still shuts down.
  • Anonymous Jan 01, 2008
    same here
  • kyhapymom Jan 06, 2008
    Whenever I hit the function button to put in a CD, it goes into stand by mode & shuts down
  • tpeterson Jan 07, 2008
    Same problem.
  • Anonymous Jan 18, 2008
You can find a digital copy of the manual here (check out the "Operating Instructions" to be exact). The protect mode os actually a method of the system "protecting" itself from short circuiting, if for some reason any speaker wires are crossed, such as taped wires have been knocked loose and are now touching, this feature will be triggered.
If this is still coming up after all wires have been disconnected then it's likely the system has actually been shorted out and/or there's an actual hardware problem. You could probably have this repaired but at the cost of systems nowadays it'd probably be cheaper to buy another system. Note though, you're speakers may still be good so you might could try buying something off ebay and reusing the Sony speakers, which imo, are a great contribution to what makes the system great.
Posted on Jan 28, 2008
I have the same problem also
Posted on Dec 24, 2007
Just hold the stop button on the unit in for 15sec!
Posted on Feb 25, 2008
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
DVD player turns on; but apperently will NOT play the movie after we put it in... HELP!!!
I had the same issue and could have kicked myself in the ***! Make sure the AV slide switch is in the out position or it will not play at all. As soon as you switch from IN to OUT it will work properly.
May 02, 2009 | Memorex MVDP1088 Portable DVD Player with...
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Panasonic DVD player stuck in safe mode
Just got off with the Panasonic people. You have to turn it on, then hold down the VCR play button and channel up button at the same time until the unit turns off. This will reset the whole player. Then turn it back on & it should open!
Nov 29, 2008 | Televison & Video
Kawasaki PVS 10921 lines in screen
unplug the device from the main power cord.remove all the external wires connected from the player.then again reconnect it properly.also check out the disc in another player.or another disc in the same player.
Nov 27, 2008 | kawasaki PVS-10921 Portable DVD Player
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Guru
I was moving around my large woofer speaker last night and then all of a sudden the unit went into protection mode. I tried all the various solutions posted on here and nothing worked. Then I went back to my speaker connections on the woofer and unplugged them and plugged them in again and it seems to be ok now. Very annoying problem. Can I suggest unplugging all the speaker cables and replugging them back in. Also another solution may have been holding down the power button when powering up the unit. Give all the above a try.
May 22, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Nov 22, 2007 | LG DK 9411P DVD Player
Dual screen car solution dvd player with games
Considering the DVD player is inside of the unit, and the unit will not play a DVD (I am assuming you put in a DVD) while in DVD mode, the conclusion I would draw would be that the unit is defective and should be returned. To give details to this deduction: DVD Mode has power, just is not producing an image. --Known because it can play games.
Jul 27, 2007 | Dual XDVD180 Portable DVD Player
Sony DAV-C770 System Logo
461 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
