Question about Ovens
Oven shuts off by itself
Kenmore digital stove - the oven turns off and comes right back on again but the oven has to be turned back on, the clock reset and the timer reset. I can't back anything without being inthe room to wee when the clock is flashing so I know I have to restart it and guess at how long it still needs to bake. I don't have a problem with the stove shutting off when just using the burners and there are no other problems that I am aware of.
  • 62 Answers
Hello
I am also having the same problem http://tvtropes.org/pmwiki/pmwiki.php/Main/IReadThatAs
this is going to help you
Thanks & Regards
Posted on May 23, 2009
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Oven won't turn on because someone played with timer
Try turning the mains supply off and it will probably reset everything.
Feb 01, 2018 | Moffat Ovens
Power was disrupted and stove needs resetting
Try turning the power off to the oven totally and leaving it for a few mins, then turn it back on. If this doesn't work you may have to have a new clock/timer. espares used to have them. If you don't see it listed, send in a request.
Jul 29, 2011 | Stoves 720EF Electric Double Oven
Clock keeps flashing i keep setting clock but after 5 minutes or so starts flashing again putting tape over ready time button to hold it down then reset clock seems to work till the tape comes loose Stove...
It looks like the clock is on its way out. I would try two things. First, turn the power off at the main switch, leave it off for a few mins and then turn it back on and see if it makes a difference. You may need to do this a couple of times. Secondly, with the power switched off, repeatedly press all the clock buttons one at a time a number of times - there may be a contact that needs cleaning by operation and then see what happens. if you do need a new clock/timer then ask espares for a quote.
Nov 14, 2010 | Stoves 720EF Electric Double Oven
Oven won't work beacuse of the timer on the stove.
It depends on the make and model and wether it is a digital clock.
But generally if you press/turn the larger knob this will reset the clock and return the oven to manual cooking .
Jan 01, 2010 | Ovens
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
190 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
