Question about Lands Phones
I bought the phone, followed instructions and charged it. But the screen does not come on. It's been 36 hours.
  • 2 more comments
  • newbelieverc May 23, 2009
    I bought am American Telecom cordless phone, model RA2184BBH. As instructed, I set the phone up and have been charging it for 36 hours. The red light goes on indicating the phone is charged, the green light is blinking, indicating there is a voice message to retrieve. But the screen is blank and I can't turn on the phone.
    I had done both of these things several times. The screen remains blank even though the lights on the base are working.
  • newbelieverc May 24, 2009
    I just changed the batteries. I put in new ones and the phone now works fine.
    Thank you for the many good suggestions. You were helpful.
    President:
  • 1,223 Answers
Pls first check the battery compartment u have got 2 AAA cells pls check the + and - signs and seating properly the battery might resolve ur problem see the negative and positive sign and seat the batt accordingly terminals are marked with those signs
secondly press the OK button for w while for like 5 sec u will see power in LCD and u will see some display
pls confirm then we can proceed further
Posted on May 23, 2009
  • 1 more comment
  • Shoaib Rais
    Shoaib Rais May 23, 2009
    http://www.atsphone.com/payntalk/RA218/R...
    user manual for ur phone
  • Shoaib Rais
    pls tell me do u see any type of power sign on hand set and also tell me have u paired up the handset with ur base unit
    do u know how to pair up the base unit with handset
    are u sure that the batteries AAA cells are fully charged and working ok , pls try them on other device for charging problems see if they work on other devices and supply power they might be faulty
    pls answer my questions and get help
  • Shoaib Rais
    Shoaib Rais May 24, 2009
    kindly rate me if ur problem has solved
    pls rate me WELL !
  • Lands Phones Master
  • 13,433 Answers
Hi
if you just got a brand new phone and it doesn't work after you have charged it - basically it should turn on even while its charging, Its most likely a faulty phone, you can get it replaced right away since its not turning on, it happens sometimes, pretty rare thought.
I can check the instructions if you tell me the brand and model of the phone.
Centech 4 in one manual says to give an intial charge of 36 hours and don't over charge. The jump starter is in the green right out of the box should I still charge it?
I would still charge it.
I'm guessing you bought this new as you said "right out of the box".
If that's the case, charge as stated in the manual and if there's any problems, take it back for an exchange or refund.
Feb 21, 2015 | Air Tools & Compressors
My MusicPad Pro Plus will not power up.
Probably your battery packs won't hold a charge any more. See my post here
Jan 03, 2014 | FreeHand Systems Freehand MusicPad Pro...
Kambrook KD36 timer instructions
1) Copy following link for 24-hour Kambrook KD-36 timer manual:
2) Add comment and describe timer in detail. Attach photo of your timer for clarification.
3) Most modern timers have non-replaceable, internal rechargeable battery that requires charging for 1 hour before programming.
Feb 19, 2013 | Hardware & Accessories
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Hallo aggelos here i have bought a hi phone j8 dual sim 3,5 screen and i put the first battery about 16 hours and the charger had a red light which never turned to green how many hours have i to charge it?...
The chinese Clone phones have very little in the way of letting you know they are charged. A regular battery will charge fully after 5-6 hours of AC mains plug time.
May 04, 2011 | Cell Phones
New battery loses charge to quickly only lasts 24 hours have tried another still the same problem have fitted phone cover
For better battery performance, perform the following tasks,
1. Switch off the bluetooth. If needed put into hidden mode.
2. Switch off the wifi netword scanning (if applicable)
3. Reduce the screen brightness.
4.While keeping in pocket, take care to ensure that the mobile screen not at all touched or pushed inside pocket even though the screen is locked.
5. Charge th emobile phone for continuous 5 hours and dont charge until fully discharged. Follow this for atleast 5 times.
Then you can see the improvement in batery backup time.
I hope this is helpful to you
Dec 31, 2009 | LG KU990 Viewty
Phone fell and the screen is black
dis assemble including lcd then assemble in 1 hour
Mar 02, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Intial charging period
yes its pretty normal the max is 36 hours for the first time to open all the cells ,after that when u charge it the current will flow in
Sep 05, 2008 | Cell Phones
Lands Phones Logo
113 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
