Question about Sony XM-2150GSX Car Audio Amplifier
Subwoofer is not working at all.
I had my 12" subwoofer connceted to the 350 watt mono amplifier working fine, and I turned my amp/car off to get gas. Upon restarting my car and turning the amp back on, the subwoofer is not giving off any sort of sounds. The amplifier's power light is on. I have made sure the wiring for the subwoofer was connected and it was. I have tried everything from rewiring my amp to rewiring my radio just to make sure everything was secure. Any and all help will be very much appreciated.
  • barnz May 11, 2010
    hi their/ have u tryd the sub on another stereo to see if its not the sub blowin it kud be ur amp!!! something might of popd of inside ur amp
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: amplifier turns on but not the subwoofer?
Hello thedj3214,
You can find the color codes for a 1999 Buick Regal here. There is no dedicated amp remote wire. Neither is there a power antenna wire.
You could use the 12V "switched lead (yellow) from the radio or any switched 12V lead directly from the vehicle fuse box. I'd wire it through a dash mounted toggle switch so as to be able to turn the amp on and off manually.
The Sony 2150GSX is a 2-channel amp with the speaker terminals on either side. You do not want to ground the subwoofer itself, only the ground terminal should be connected to bare metal on the vehicle chassis or body as close to the amp as possible. The ground wire does not need to be run to the negative battery terminal.
A ground on one of the speaker leads will probably cause the amp not to power up. A ground on a speaker wire usually activates the amps protection circuit, causing it to not operate until the fault is corrected.
Hope this helps.
Posted on Jul 29, 2009
  • 49 Answers
SOURCE: Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Posted on Feb 10, 2010
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
What car amp should I get to power my 2 pioneer ts-sw3002s4 sub's. They are 12 shallow mounts 4 ohms each with 400rms each.
Rockford Fosgate R1200-1D Mono subwoofer amplifier - 800 watts RMS x1 at 2 ohm, 1,200 watts RMS x 1 at 1 ohm
Mar 26, 2015 | Pioneer Car Audio & Video
Can i use my jensen 340 mono amp with a 500 watt 15'' subwoofer
You can, but I wouldn't advise it. Won't sound that great, your probably going to overheat your amp. It may go into protect mode. You need a bigger amp.
Dec 13, 2011 | Jensen JXP340 Car Audio Amplifier
I have a Alpine MRP-M350 amp and then I have 2 10 Kicker Freair F10A Subwoofers. What's the best set up for this combo?
From the plus(+) of the speaker output on the amplifier run a cable to the plus(+) on the voice coil of the first subwoofer then follow thru with the same cable to the plus(+) of the other subwoofer.
From the minus(-) of the speaker output on the amplifier, run a cale to the minus(-) of the first subwoofer then follow thru with the same cable to the minus(-) of the other subwoofer.
This will make your amplifier run @ 2OHMS and provide you with 350 Watt RMS which will work fine even if you run your subwooffers free air(without a box))
hope this helps
dreamsystems
Feb 06, 2011 | Alpine MRP-M350 Car Audio Amplifier
AMP
That amplifier is only stable to 2 ohms.
You will only be able to use one Dual 4 ohm Subwoofer wired in parallel (all + to + on amp.... all - to - on amp.
This will yield a 2 ohm mono load.
It is impossible to wire (2) dual 4 ohm voicecoils to achieve a 2 ohm mono load.
If you're set on using both subwoofers - they will not be getting as much power from your amplifier with a 4 ohm load - but it is your only option.
SEE THIS LINK for the wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 02, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Output problem
dude TRUST me what you are using and have setup already is plenty..ONE TIP...of all things anyoine ever needs to worry about is the R...M....S power rating...the PEAK means NOTHING! its safe and fine to use what you got.
Jul 02, 2009 | Jl Audio 250/1 Car Audio Amplifier
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Trying to figure out what kind of amp i got amercian pro vs-3507?
The VS3507 Is a class D monoblock.
Your optimum wiring for this amplifier is a 2 Ohm load - so it produces its full potential power of 350W RMS.
To Achieve a 2 ohm load, the most common load is one of the following...
(1) Dual 4 Ohm Voicecoil Subwoofer Wired in Parallel.
(2) 4 Ohm Voicecoil Subwoofers wired in Parallel.
(1) Quad 2 Ohm Voicecoil Subwoofer wired in Parallel/Series.
(1) Single 2 Ohm voicecoil subwoofer.
American Pro VS3507 2000W Car Audio Monoblock Amplifier
American Pro VS3507 Monoblock Amplifier Details
  • Built-In Crossover
  • Variable High/Low Pass Filters
  • Phase Shift Control
  • Subsonic Filter
  • Bass Boost Control
  • Dancing Lights at the Rhythm of Music
  • Protection Circuits
  • Gold Plated Terminals
  • Power & Protection Circuit LED
  • 1 x 250 Watts RMS @ 4 Ohms
  • 1 x 350 Watts RMS @ 2 Ohms Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 29, 2009 | American Pro Car Audio & Video
Amplifier and subwoofer
Yes, it should have little trouble. You will be best to keep it 2-channel and get another Sub. then run both. if you bridge it you will blow your 1 Sub. DON'T FORGET to put a in-line Low Pass Crossover in front of the Amp. OR any Sub.(one for each if you do go for 2) as they were never made for the high frequencies. An adjustable one is best for fine tuning. In thory you have a 600 watts buffer that way. If you do it Mono you are 400 watts over. If you want to go Mono you will need over 2000 watts on the Sub. end to turn it right up. Oh and some good ear-plugs if you want it loud whilst you are inside the car.
Dec 26, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Subwoofers
This will depend on the amplifiers capabilities.
I will give 2 different scenarios.
#1 Stereo configuration
If the amplifier supports an RMS power output close to the RMS input power of the subwoofers then run the amplifier in stereo mode. For example 150 watts RMS X 4 channels driven at 20-20khz. (If you can provide a model # for the subs and the amp your looking at I can help you further with this decision.
Wiring for this is easy and simply involves matching the connectors for 2 of the channels (Front or Rear) to each of the subwoofers.
#2 Mono Bridged mode.
If the amplifier is lower power but mono bridgable you can bridge two Pairs of channels and power each of the subwoofers this way.
Generally speaking a 2 channel bridgable amplifier will be able to at least combine the wattage of each channel into a single monural channel and in many cases its actually higher.
So you would bridge the front 2 channels into a single bridged mode for one subwoofer. and then you could bridge the read 2 channels into another bridged mono channel for your other sub woofer.
For example if you had bridgable amplifier thats 50 watts RMS X 4 you coudl very likely (Generalization based on quality of amplifier) send 150 watts RMS to each subwoofer.
Again I would need to know what amp you're refering to to provide specific wiring instructions. Many Bridging amplifiers either have a single switch that will send them to bridged mode or you would use the positive + terminal from one channel and the negative - terminal from the other channel or a combination of both.
Sep 17, 2008 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Sony XM-2150GSX Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
