Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
2000 400 Explorer engine won't shut off
I recently replaced my engine, starts and runs fine and everything worked fine prior to replacement. Just won't shut off with key or run sw. Checked grounds, thought maybe CDI box not working correctly? Help please .
Thanks, Bill
  • 4 Answers
Make sure the black wire coming from the CDI is connected tightly/clean.
Posted on Jun 29, 2009
Engine won t shut off
Poor ignition switch .Replace it and check for the blown fuses & your problem will disappear .As ignition controls the current to ECU so if the ignition will still be transmitting the voltage to ecu with the key turned off so how will a engine shutoff? think it's logical.You have been tricked by mechanic as it's not the computer fault at all.
Dec 12, 2013 | Dodge Grand Caravan Cars & Trucks
01 ford explorer sport won't stay running. turns over fine and starts but quits right away
Check for vacuum leak at intake manifold or bad fuel pump relay or have fuel pressure checked to see if fuel pump is working properly 40-45 psi it should be pumping
Dec 18, 2011 | 2001 Ford Explorer Sport
My 01 explorer sport won't start, I had the battery charged and tested and then the car started up, later that evening I went to start the truck and it would not start. The following day I took the...
It sounds like a fault in the starter circuit. It could be a defective neutral safety switch, starter solenoid, or possible a defective ignition switch but I doubt it. Can you hear the starter solenoid??? I'm willing to bet the problem is either with starter relay, neutral safety switch, or starter solenoid.
Sep 21, 2011 | 2001 Ford Explorer Sport
M y 95 Explorer drives fine it has 291003 miles on it but it just recently started making a little rattling noise in the engine it still has the same power it just has that funny little noise
Thats not bad almost 300000 the engine runs grate doesnt smoke you took good care of it it just worn out you need to rebuild or replace it
Aug 24, 2011 | 1995 Ford Explorer
Difficult to start up sounds sluggish, once shut off, won't start, coil was hot (coil recently replaced). Needs new muffler.
Replace spark plugs with new ones. put new muffler in. The muffler has an affect on the way engine runs. (back pressure) is needed. At this age you may need a head gasket(s). Compression check on all cylinders. The list goes on... Good luck
Jun 10, 2011 | 1982 Ford F 250
Where is the fuel shut off switch and how to reset it on a 2000 Ford Explorer. I have replaced the fuel filter, it was running fine, then just won't start (cranks and cranks) and someone suggested it may...
The Inertia Fuel Shutoff is located in the trunk, on the LH hinge support.
All you need to do is press the reset button located on top of the switch.
Oct 20, 2009 | 1989 Ford Tempo
03 Mini Cooper Power Steering Fan will not run
2006 mini cooper s power steering fan seezed. replaced with new fan won't run?
Mar 30, 2009 | 2006 Mini Cooper
Fuel pump relay & fuel pump
when you turn the key on the pump should run to purge the system . so now you have fuel pressure for starting. this stage lasts about 10 seconds then the fuel pump doesnt turn on again till the computer see's oil pressure then turns the pump on. if the inertia switch has been activated it wont send the first amount of fuel.
Jul 26, 2008 | 1996 Ford F150 Regular Cab
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
307 people viewed this question
Top Interactive Toy Concepts Toys Experts
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
