Color problem big red dot in the centre and the other colors around it but the picture is all there just the color is messed up. can you please help with this problem and where can i find the circuit diagram.thank you so much Tinus Dippenaartinusd@telus.net
  • tondo Dec 06, 2007
    I get tiny red dots in the screen, especially during the night scenes when it's dark, or when I turn the TV on, and the screen is still blank, you'll notice those same red dots right before the program comes on. What's causing those dots to appear?
    Problem Solver:
  • 7 Answers
I dont know if this will help , but i bought a rca and a month later i had a big green spot in the middle of the screen, the tv repairman replaced one of the three color modules
Posted on Oct 20, 2007
I can't change contrast and brightness on screen
Posted on Jan 18, 2009
Why do I get red and blue dots when prnting pictures?
THIS machine has tendence to SPILL toner. Remove toner WASTE RECEPTACLE and GENTLY remove toners and DRUMS. check residuous acumulated over the transfer belt (do not touch or use chemicals on FUSER OR TRANSFER BELT .ALSO CHECK IF THERE IS TONER RESIDUOUS IN THE TRAY OR PAPER PATH. IF USING AIR CAN; COVER THE LASER UNIT (OF EACH COLOR) TO AVOID ACUMULATE IT AT THE LASER COMPARTMENT.
Dec 10, 2014 | Lexmark CS410dn Color Laser Printer...
Lines
The convergenceboard is on the fritz. Located on the small signal module, there are two convergence ICs that will need replaced as well as several resistors. See a tech to repair this! Please do not adjust the screen colors or turn any potentiometers. It does not sound like you are in big trouble yet! Thanks for asking!
May 02, 2010 | Philips 50P8341 50" Rear Projection...
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
Green shadows around small red objects (football players with red shirts)
turn tv of by power point for 1 hour then switch back on that resets the picture if still happens may need a service
Jan 27, 2009 | RCA HD61LPW164 61" Rear Projection HDTV
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
HITACHI Projection TV 53FDX20B having too much red color
my hitachi projection big screen tv 57SWX20B has a draping affect across top of screen why?
Dec 30, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Need to find out how to adjust color
im curious why you think you need to ajust the color do you have red screen? or missaligned colors?
If your B&W images look okay (bright and dark areas), either films, ads,
or turing the color off, you shouldn't tinker with grayscale
adjustments. You'll really mess up your set. Haven't seen many
complaints about 'red push' with Pioneers, but that may be the problem.
A further check would be the decoder test on the Avia disc. Also visit
http://www.hometheaterspot.com/ and search the Pioneer section for
similar complaints.
Nov 16, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red drained out of picture
The red transister on the CRT socket could be at fault. there is 3 transisters on the socket check for the voltages on all 3. If the red is high unplug the socket and see if it normal if not the transister or circuit feeding has a short. If low the same case seneral applies and a resistor feeding the transister is defective or the transister itself is at fault
Aug 28, 2006 | Panasonic CT-32SL15 32" TV
Televison & Video Logo
274 people viewed this question
Top Televison & Video Experts
