Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Element hi my problem is the element bottom and middle does'nt fonction
  • 87 Answers
You need to remove the element and connect an ohm meter to each end. If the resistance is infinite, the element must be replaced.
Posted on May 23, 2009
New element touching bottom of oven. Two small holes in over.
The element should not touch the bottom of the oven. I would call up the person that did the repair and tell them about the small holes. This may be a fire hazard. You should not be charged for work that was done improperly.
Oct 28, 2015 | Ovens
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
How do you change the oven element on a Westinghouse PAJ143W as the element is hidden
To replace Westinghouse PAJ143W oven element you need to look at the back of oven with a torch etc, and you will see the element ends go into the back through clips on each side. At the top of these clips in the middle there is a bit where you get a screwdriver to push down and lever forward and it will come out a bit you do this on both sides. Then lift the clips and element 'both sides'' together and carefully pull forward making sure you're careful with the wiring and pull out a little making sure you stop the wires slipping back while you swap elements. Make sure you put plate at front back in place to keep element up off the bottom, it has two reswts for element on it.
May 20, 2012 | Sharp Ovens
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
Can I use all shelf positions. Which positions are best?
If you are referring to the main oven, all shelf heights can be used. If you are using the rear heating element with the fan, then I would always suggest using the middle shelf.
If you are using top/ bottom or both heating elements instead, then place appropriately i.e. if using top heating element then use middle or lower shelf positions and if using bottom heating element then use middle or top shelf positions
Sep 08, 2011 | Bosch Ovens
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
95 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
