Question about E-Machines eMachines Desktop PC
Sounds like an airplane
The moment i move the mouse the computer sounds as if there a big fan on the inside of it
  • Michael Rodriques May 11, 2010
    Are you certain that it is only when you move your mouse? There are two fans inside of e-machines, 1 is on the motherboard (above the CPU) and the other is on the back of the power supply, but neither of these should be affected by mouse motion.
    Sergeant:
    Champion:
  • 212 Answers
That is your internal fan. shut down the computer open it up and vaccum it out. if that doesn't work replace the fan.
Posted on May 24, 2009
Engine sounds like an airplane taking off
Sounds like the engine cooling fan clutch is defective. If it remains locked up the noise does sound like an airplane.
Mar 18, 2015 | 2009 Chevrolet HHR
I must have hit a button and now the cursor is showing up on the big screen off the projector but I only want to see it on my laptop while doing my presentation.
Hi renee_pott, "You can choose the "Mouse Options" in the Control Panel.
First, click on the -> Start button -> Control Panel -> Hardware and Sound -> Mouse ->
Mouse Properties -> Pointer Options.
Try one 'or' more options:
* Snap To, place a (Check in the box) !
* Hide pointer while typing !
* Show location of pointer when I press the {CTRL key} !
  • Usually the "Mouse" pointer by { Default }, is displayed during a slide presentation, and when the mouse is moved.
  • " Try pressing the {Ctrl + H keys to "Hide" the mouse pointer}."
  • Left-clicking on the "Mouse" button, will advance [forward] the slide show.
  • Pressing Ctrl + A keys, will restore the "Mouse" pointer.
!"Take a moment to rate the help."
Thanks paul7of9
Mar 23, 2011 | Computers & Internet
02 Trailblazer Loss of power - replaced fuel filter, - rpm's rise but no accelleration -engine cold or hot does not matter- I hope that it is not the transmission - I read where a bad fan clutch can...
If the fan clutch is bad, your engine would sound like a big rig or an airplane and get louder as you press on the gas more. Do you have a check engine light on?
Feb 23, 2011 | 2004 Chevrolet TrailBlazer
My 2002 Chevy Trailblazer started acting like it is having trouble getting air. It is not missing and transmission is shifting correctly but is seems like is is struggling for air. Engine sounds like it is...
Does it sound like an airplane or a big rig when you give it gas? If I'm reading you right here, sounds like your fan clutch is stuck engaged. Need to replace the fan clutch, this is a common problem for TB's.
Jan 26, 2011 | 2002 Chevrolet TrailBlazer
When I turn on the fan past the 3 speed it sounds like a low,loud, growling sound like it has airplane engines turning on. I also smelled a fowl odor in side my car, my husband thinks a field mouse is in...
It's very possible that a mouse has gotten into the duct work and ended up trapped inside the blower motor fan. The now dead mouse would cause the blower fan to be out of balance & wobble considerably and make noise plus it would smell quite a bit. I see a handfull of dead mice in blower motor fans each year so it's not all that uncommon. The fix is to remove the blower motor and clean out all the debris. Most of the time the blower and fan are fine and can be reinstalled once they are cleaned up. Hope this helps you find your problem!
Jul 12, 2010 | 2000 Honda Accord
Why does my nas sound like an airplane taking off from time to time. It's been doing it more lately. A sign of impending trouble?
Sometimes, the fans inside a computer are "heat-controlled", i.e., the warmer that it is inside, the faster (and noiser) that the fan will run.
If there is no fan, then it's the bearings inside the disk-drive that are worn out -- as you state, a total disk-drive "crash" is not far away.
Jun 15, 2010 | Iomega (33033)
The mouse has lost its air feature. Still works from a desk as an optical mouse. Produces a high pitched sound .
Sorry my reply is five years after the question but I really hope this reply can help anyone out. I have a gyration GYR3101US Media center remote.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-0.jpg I love this remote/air mouse but after I dropped it about two months back anytime I would try to use the air mouse, it would emit a loud high pitch sound and put the cursor near the time clock unable to move it. Tonight I took it apart. this is what I found. There is one screw behind the batteries, then you have to pry it apart with a flat head. once inside find the gyration sensor
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-4.jpg CAREFULLY pry apart the sensor with a little flathead, there is a metal plate on the bottom of the sensor so DO NOT pry from the circuit board up that will break the sensor off. Put the screw driver between the metal plate and the outer casing you should see a little crack. also i cut most of that red tape off with a razor blade before prying.
mouse-lost-its-air-feature-still-works-nec1hkrws0ash25xby3rpbkt-5-7.jpg The red arrow is pointing at the part inside the sensor that had come lose from the drop and was moving about freely inside. I'm guessing it's a weight or magnet. After carefully and gently snapping it back in place, put your mouse back together enough to test it. at first it still had problems but i double clicked the mouse movement button and set it on a flat surface so it could calibrate itself. SUCCESS. I hope this helps my gyration is working fine now. contact me if needed john4628 AT gmail. (There are no fans or bearings in this mouse or any gyration mouse)
Feb 05, 2010 | Gyration GO 2.4 Air Mouse/Compact Keyboard
My 2001 Nissan has noisy blower. Sounds like a airplane when it's on 2-3-4. Replace blower?
theres a good chance a small mouse or other animal has crawled into the fan and died, pull down the fan motor and clean it out,
Jun 29, 2009 | 2001 Nissan Sentra
Emachines w3503
Your processor fan or system may be producing the noise. First you try to cliean the fan if there is dust inside. Still there is problem you have to replace the fan
May 23, 2009 | E-Machines eMachines Desktop PC
My children were messing up my computer by switching it on and off many times. At the moment the screen is slightly moved to the left and there is a big black stripe on the right side; i can't move the...
If you run the mouse up the side does a little arrow appear? If it does you can pull on that arrow, using the mouse and recenter your display. Try this first and if it doesnt work, get back to me.
Aug 21, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
173 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
