Question about Sunbeam SCA103RWB1 Room Air Conditioner
ERROR CODE e2
HAVEN'T USED THIS UNIT SINCE LAST SUMMER IT NOW SAYS E2 ON THE THERMOSTAT. i'M GUESSING THIS IS AN ERROR CODE....ANY WAY TO RESET IT?
5 Suggested Answers
SOURCE: My Heat will not work
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Posted on Dec 22, 2008
SOURCE: e2 CODE ON SUNBEAM SCK14200DR
I just fixed this on mine one minute ago.
Take off the front panel.
You will see a black wire held onto the heat fins by a plastic clip.
This is the thermocouple that measures temperature.
Mine became unplugged from the circuit board and plugging it back in fixed the problem.
The wire goes into a steel box.
take off the screws on the bottom of the box, grab it by the lowed left corner and bend the metal up as far as you can.
The wire plugs into a small white connector on the circuit board.
plug it back in, bend the metal back down, screw it in, replace the cover, and you should be good to go.
-Alexander W MacFarlane IV Ph.D.
Posted on Jun 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
SOURCE: The thermostat is flashing and E2 error
It means the trailer is too warm for the thermostat to work - above 90 degrees inside. Take some ice and put in ziplock bag - place over thermostat and cool it down. Unit will start working when thermostat senses it is BELOW 90 degrees. FAULTY DESIGN.
Posted on Jul 15, 2011
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
Just installed, shows error code E2, is not heating water
May 22, 2015 | Water Water Heaters
I have a ge air conditioner model AHM24DPH1 WITH an error E2 / E1. What do I do to possibly fix.how do I reset maybe
E1 is humidity sensor error unplug unit and then plug it back in.
E2 is Temperature sensor error unplug unit and then plug it back in this will clear codes. if codes come back on then you will need to replace sensors.
Jun 24, 2014 | Heating & Cooling
Ductless split
Not familiar with this particular unit, but whenever the breaker trips it indicates a problem with the compressor motor. Check it for a short or ground.
Sep 04, 2013 | Carrier Heating & Cooling
P2 and it's almost new
I think the Error Code you saw was 'E2" On the LED screen an 'E" can look like a 'P".
In any event, the E2 Code means "Sensor protection, to avoid occurrence of unit damage, auto-stop protection." In simple terms, the unit sensed something is wrong with one of the electronic sensors and shut the unit OFF, to protect it from further damage.
Since your unit is "almost new" (hopefully under 1 year old). If you haven't registered your warranty yet with LG, do so immediately @ https://secure.prodregister.com/lg/air_conditioner/urv_1.shtml?mset=ac&cname=Air%20Conditioner
Then submit a Warranty Claim http://www.lg.com/us/support/repair/support-warranty-claims.jsp
Hope this helps you.
Jul 09, 2011 | LG LP0711WNR Portable Air Conditioner
I have an E2 error code, how do I resolve this
I simply disconnected my battery to reset the thermostat and my E2 problem fixed itself...
Jun 07, 2011 | Dometic Rooftop RV Air Conditioner
How do i reset the E2 code error on the aircon the model is convair supercool portiable unit
E-2..(Thermostat sensor)This error means that the unit has gone into a protection mode.
Check indoor coil sensor circuit closed. Check with ohms testing two ends, should read something. If it doesn't read any thing, replace the sensor.
Dec 16, 2010 | Convair Portable Air Conditioner
What do codes e2 and f1 mean?
Here is what the manufacture says about it, my comments are below.
F1 E2 - UL A/D error(s)
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Phil's comments----->
F1 Codes are related to the control itself, if there was a storm, power outage, surge etc it could have damaged the control. Try resetting the board by unplugging the range or turning off the breaker for a couple minutes. Restart and see if that helps. If not you will need to replace the control.
The part number for this unit is 4453614 and runs just over $300.00
Apr 25, 2010 | Whirlpool GR465LXLS Electric Kitchen Range
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
Dec 03, 2008 | Carrier Heating & Cooling
E2 error code
In reading the manual for this coffee pot, it needs to have the descaling procedure run. The manual lists running a mixture of 6 cups water and 6 cups vinegar in a normal brew cycle...twice to clean hard water deposits from the machine. It says to make sure to remove the filter basket. Once the procedure is complete, unplug the unit and replug in to remove the E2 code.
Jul 26, 2008 | KitchenAid Pro Line Coffeemaker Coffee...
Sunbeam SCA103RWB1 Room Air Conditioner Logo
76 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
