Question about Whirlpool Duet GHW9150P Front Load Washer
Water Leak Hi, When I run my washer I notice that water is leaking from somewhere under the washer as evidenced by the pool of water that is on the floor just underneath the washer. It is not coming from the door.
  • Nanette Nov 01, 2007
    My Duet leaks from the bottom also.  I have the optional pedestal, and the contents of it are dry, but the left side of the washer leaks a significant amount .  The bellows was replaced 4 months ago, and I wash about 2 loads/day.
    Problem Solver:
I also had this same problem and I had a huge rip in the bellows...
Posted on Nov 07, 2007
  • 64 Answers
When the machine has filled TURN THE POWER OFF.then tip the machine back & lean it on the wall, look around for the leak it should be fairly easy to see. It may be the door seal which has split, you should be able to see this be examining the seal with the door open
Posted on Oct 26, 2007
I have a D3432 and had a blocked pipe that kept the motor running. I opened the toe kick and drained the water from the bottom tray which seemed to have solved the motor issue but after running the machine...
Well, there are a couple of places where washers can leak.
  • There are a couple of hoses underneath: from the tub to the water pump, and from the water pump to the drain connector.
  • The fill sensor switch has a length of small diameter tubing that connects to the outer tub.
  • The tub itself could rust through (as it did when my 1984 washer was about 22 years old)
  • The seal or bearing where the motor shaft goes through the outer tub could have failed.
You will have to take the back cover off and run a cycle to identify the site of the leak.
Nov 25, 2014 | Washing Machines
Barracuda automatic pool cleaner
try hose into skimmer hole maybe air leak from plate make sure swivel end of hose on cleaner maybe air leak if sticking out of water
Dec 26, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
I changed my water control valve, thinking my dishwasher was not getting water, however, if I put water in the basin, dishwasher pumps the water out, however, it sounds like the dishwasher stays stuck in...
There is a simple explanation for this - water is leaking into the bottom of your dishwasher under the washing compartment. This has caused the float to rise and trip the switch which activates the Aqua-Stop / anti-flood protection system. This also closes the solenoid (water control valve) which explains why you thought it needed to be replaced.
The only way to check this is to remove the washer from under the counter (disconnect power and water supply first) and tilt it backwards about 15-20 degrees. Water should run on to the floor from under the washer so I suggest putting some old towels down first. Once the water has been drained from under the washer, you can use it again, but it's not advisable if you have a leak. The only way to find the leak is to get access to the bottom of the washer by removing a side panel, usually the right-hand one. As you already replaced the solenoid, you should know how to do this. Once you have access you can run a cycle and try to see where the water is leaking from or you may be able to see signs of corrosion somewhere which should help you to identify the source of the leak.
If there is no water under the washer, you probably have a faulty float switch or possible a faulty control module.
Hope this helps. Post back if you need further assistance.
Regards,
BElectric
Nov 23, 2010 | Bosch SHU9915UC Dishwasher
My Gaggia Syncrony Compact has developed some sort of leak. Every few days I notice a pool of water spreading across the countertop in our pantry and pooled under the machine. The leak might be happening...
HI
I would suspect the seal on the machine where the tank sets on the machine. There is a plastic cap that looks like a doughnut, that will pry off (there are 2 hooks, 1 on each side). The seal is under neath. If you can stick your finger in the center of the seal and lift it out it needs to be replaced. When you put the new one in, run your finger nail around the outside edge of the seal to get it to slip in or you could damage the new seal.
Oct 24, 2010 | Gaggia Syncrony Compact Coffee...
Im filliing my intex pool and found water trickleing from underneath, how can i find the leak. or should i continue to fill to better locate the leak?
Now let's find that leak! Fill the pool to its normal level and mark it. A piece of duct tape is ideal for this. Next with your filter system running the whole time, wait 12 to 24 hours and measure the loss of water. Then refill the pool back to the same level and with the filter system off, wait the same amount of time (also over the same part of the day, ie. 8 AM to 8 AM or 7 PM to 7 AM) and measure the water loss.
If you are losing more water with the filter system running, the leak is on the pressure side of your plumbing somewhere PAST the impeller of the pump. If you are losing less water with the filter system not running, the leak is on the vacuum side of your plumbing somewhere BEFORE the impeller of the pump. Please note that in this case, most of the time the pool only loses water when the system is off and not when it's on. If the water loss is the same, then your leak is in the structure of the pool and not in the plumbing.
Let's deal with a leak in the plumbing first. We will assume that there is not an obvious leak (one that you can see) on the filter system. Did you check where your backwash line comes out? There are two ways to find this leak. First, you can pressure test the lines, then dig, following the leaking line till you find it. You can also call in your local leak detection service. We would highly recommend the latter, unless you like to dig. Professionals will use "geophones" to listen for the leak and only dig where necessary!
Now lets look at a leak in the structure of a concrete pool. You will need some food coloring for this, and you will want to turn off the pump at least an hour before you do this. In a concrete pool, any cracks in the shell are usually obvious. By squeezing out the food coloring near the crack, you will see the crack pull the food coloring in. That will show you where the pool is leaking. Yes, you may have to get in the pool to do this, but isn't that why you got the pool in the first place? If there are no visible cracks, you will want to squeeze out the food coloring around any of the items that pierce the shell of the pool (main drain, returns, lights, etc.). Be sure to check the "mouth" of the skimmer where the plastic of the skimmer meets the concrete. This area is very susceptible to movement and often separates causing a leak.
Once the leak is found, it is easy to fix using a patching material. Most of them will work under water. After patching, check again with your food coloring to make sure you plugged the leak. Please note that if you patch near a fitting, you will want to leave the pump off while it cures, so the flow of water doesn't wash the patch away.
What if you have a vinyl pool with a leak? A leak can be a little harder to find and fix in a vinyl pool, but it's not impossible. We would recommend that you first check around all the items that pierce the liner (main drain, returns, lights, etc.). If you find that the liner has pulled away or is leaking behind a fitting, we would STRONGLY recommend that you call in your local pool professional at this point. If you mess this repair up you could easily be looking at a new liner!
If you do not detect a leak around the fittings, you will need to search the liner itself. A lot of vinyl liners have a pattern on the walls or bottom which can make it difficult to see a hole. Sometimes by running your hand over the floor and walls you may feel a tear or puncture that's not easily visible. If you have a friend who is a diver, he or she can do the job a lot easier with a tank than you can by holding your breath. Note: only certified divers should be using diving gear, even in a pool. Sometimes there is a depression on the floor which might indicate erosion caused by the flow of water. After finding the leak it is an easy matter to patch, using a vinyl patch kit and following the directions.
i hope this helps...let me know, thanks and good luck
Jun 27, 2010 | Intex Easy Set Pool 15x36
My car leaks water, but not from the radiator
water or coolant? if it is juat plain old water there is nothing to be concerned about it is likely condensation from somewhere. if it's coolant you will notice that the level will be droping consistanly. Check all of the hoses going to and from the radiator and the heater core and the coolant resuvoir, look on the engine block for pooling somewhere it might help in locating where the leak is. Leaks are sometimes very difficult to locate because the fluid can run down the outside of a hose or a part of the car and drip in another area away from the source.
Feb 16, 2010 | 2000 Daewoo Lanos
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Leak
It sounds like you have a leak somewhere around the door bellow. This is the rubber boot that seals the wash tub to the door frame. Pull the folds back and inspect around the entire perimeter of the rubber. You could have a small rip or tear somewhere. There are a series of small holes in the bottom of the bellow that are supposed to be there. This is the allow any standing water to drain back into the wash tub. If you cannot find any obvious signs of leaks, remove the lower panel under the door. This is accomplished by removing the screws under the bottom edge of the panel. With the screws removed, the panel will drop down, then off. Start the washer on a normal wash and watch for any leaks. If the door bellow leaks, the front counterweight (usually a concrete block) will begin to get wet and drip. This could also be an indication of the bellow clamp around the wash tub being loose. If the leak starts to pool under the washer and run out the front, this is usually an indication of a drain pump leak or drain line leak. Please inspect the washer with the panel removed and the washer on a load and post back and let me know. Go to my profile and use the "Ask Me" feature for a quicker response. I hope this helps you.
PS One other item. On the left hand side of the door bellow is the a dispenser tube that penetrates through the bellow and allows water to enter the wash tub. Sometimes the dispenser tube is not seated all the way into the rubber (should be seated past the flange) and it will dispense water behind the rubber instead of into the wash tub. Just something else to consider...
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
238 people viewed this question
Dan Webster
Dan Webster
Sal De
