Question about KitchenAid Washing Machines
How do I check the filter?
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
SOURCE: My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
Posted on Dec 18, 2008
SOURCE: Our KitchenAid KAWS850LE1 Washing machine will not drain or spin
you need to replace the lid switch
Posted on Dec 23, 2008
SOURCE: i have a kitchenaid superba dishwasher wont drain
does it make a buzzing sound when on pump? if so then the pump is trying but is either jammed or there is a blockage in the waste hose/outlet u bend. try seeing if there is a blockage in the waste hose first.
Posted on Mar 13, 2009
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see
o circular lid there, turn it on anti-clockvise to open. All of the
water blocked will come from there, be careful. Look carefully that
there are some objects blocking the water draining. Then turn on the
machine on draining programme, the plastic rotor should turn fastly
when the machine is on. If it is not running, change the pump motor. If
it is running, but machine is not draining again you can understand
that there is an objeck stuck on the hose between drum and pump motor.
Lay down the machine on its rear facade, you will see a large and black
hose between drum and pump motor. When you remove it, you will see that
there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
Posted on Oct 04, 2009
Jul 30, 2014 | KitchenAid Kitchen Aid Superba Series...
Apr 15, 2013 | KitchenAid Washing Machines
Mar 11, 2013 | Washing Machines
It is possible that the
machine does not start off the cycle because there are errors or feedback from
the inputs. For the program to start up the main program controller must
initiate the INLET/PUMP MOTOR/DRAIN to work
when it is commanded .If this does not happen then the voltage at these
points must be checked or the fault
relates to no voltage/drive from the controller. This means the controller is a
suspect.
Check how
to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the
water flows then the flow should be good, if not the inlet valve is bad or there
is dirt in the filter. Also check the flow at the inlet of the water line. What
is most important for the motor to start functioning is that the door switch
must be ON when the door is shut or this will be an error for starting the
motor. The water pressure must be good and the spraying must be seen to be
good. If there is low pumping or pressure then the spray arms will not turn
around to inject with pressure. If so
the pump must be checked for clogging.
To replace
check this link:
Jan 11, 2013 | KitchenAid Superba KUDE40FX Fully...
Dec 08, 2017 | KitchenAid 24 in. KUDU02FR Built-in...
Jul 15, 2011 | Washing Machines
Dec 08, 2009 | Washing Machines
Aug 05, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Feb 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Mar 01, 2018 | KitchenAid Washing Machines
1,051 people viewed this question
