Question about Garden
My mtd pinto mower engine cuts out when cutters engage - why?
Everytime the cutters are engaged the mower engine cuts out. The engine is misfiring as well . Any ideas please?
  • linda_hook May 30, 2009
    Thanks for the info !
    Problem Solver:
  • 16 Answers
It sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
Posted on May 30, 2009
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
John deere
Is there a safety switch anywhere you overlooked?
Sep 01, 2014 | Garden
Toro riding mower stopped cutting but still runs
Check if your drive belt has broken / come off the pulleys.
Also, if it has an electromagnetic cutter engagement, is it engaging the cutter drive?
Jun 17, 2012 | Toro Garden
Mower cuts out when cutter engaged
Check your blades for turning. A OTHER REASON COULD BE THE AIR FILTER GOT WET. If got wet. Put in the sun for a few days.
Mar 03, 2012 | Garden
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
My husband says our mower wont cut in reverse but i have before
It will cut in reverse, but because of the rotation of the blades and where the discharge shoot is located it doesnt cut quite as good because it is try to discharge the grass on the opposite side of the deck while going backwards. Also, the is a factory installed safety switch that will kill the engine when the transmission is placed into reverse with the mower deck engaged. Because I dont wish for anyone to be accidentally injured do to the safety switch being bypassed i will not tell you how to bypass it. I know it is a pain in the **** that the thing quits everytime you just need to go back a few inches. Just find someone who will show you how to bypass it, its real simple.
Apr 25, 2009 | Mtd Garden
Garden Logo
505 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
