Question about Kenmore 44102 Front Load Washer
Leaking boot at kenmore 44142 frontloader
I bought replacement bellows and need help with installing
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Boot rips
The door bellow on front loaders do wear out and require replacement. However, overloading the washer can contribute to premature wear or rips and tears due to items getting caught in the seal. If the bellow is ripped, it will require replacing or the washer will leak. The following link explains step-by-step how to install a door bellow on a Kenmore Elite front loader:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time.
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
Nov 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
KENMORE FRONTLOAD WASHER Model# 41741052000
very common for the tub seal to leak - or bellow to be ripped.
Aug 07, 2009 | Kenmore 44102 Front Load Washer
Have to replace bellows on kenmore frontloader 44142 bought in 04
Not too hard, just need a couple of tools and an hour or so. First, open the door. Next you need a thin bladed Richard brand knife model #S-12 or a razor blade and a flat thin screw driver. The seal has been glued on and you need to find a place that you can slip the screw driver between the door and the seal. Jently pull as much of the seal away from the machine as you can. Once you find a glued piece slip the knife bewteen the seal and the machine to cut the glue. It is good glue so it will take some time to do this all of the way around the door opening. Once all of the glue has been cut, undo the plastic water spout clamp, reach inside of the machine and grab the seal by the top of the wash tub. Pull down and out at the same time and the seal will come out with a little effort but watch out for the tension spring. The spring has some tension and could come out rather quick so do not have your head by the door when doing this step. This concludes the removal and since you bought a new seal, all that is neccessary is to clean off all of the glue residue on the machine and the years of grime on the tub where the seal goes. Clean these areas very well and it will pay dividends later.
To install the new seal look on the wash tub at the top and bottom and there should be an arrow cast into the plastic in one of the locations. Line up the arrow on the rubber seal (search for it) with the one on the wash tub. Carefully instal the seal by having a finger in the seal groove and hooking the seal over and under the wash tub lip. Do not let the arrow slip to a new location as you are doing this. Once the seal is in place double check to make sure that the seal is properly installed. Now gently push the seal into the wash tub so that you have access to the outer lip of the wash tub where the tension spring goes. 2 people are required for the next step. One person will place and hold the spring in the groove and another person will stretch and feed the spring in both directions around the spring groove. Take your time and do not loose your cool with this step. If you need to use non pionted or sharp tools to assist, what ever works is fine. Once the spring is in place you need to reglue the door seal to the machine. I use black RTV silicone from your local auto parts store. Place some glue into the channel and pull the gasket out from inside the machine. Slip the seal over the lip all of the way around the door opening and remove any excess silicone. Let this cure over night before using the machine. That is the end and the door seal is replaced.
May 23, 2009 | Kenmore 44102 Front Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
How do I replace the kenmore he2 bellow?
door boot not eady to install,, if you can but machine on a 45 tipp back and place 4x4 wood to hold in front it has a clamp remove ,, now there is another clamp once u can remove boot ,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 44082 Front Load - Door Leak
you did fine several companies built kenmore for sears yours looks like a frigidaire on some models there is a problem with water collecting at the bottom of the door where the bellows or boot is and leak to correct this they came out with a new boot that has a channel at the bottom with three holes in it so the trapped water can drain back into the tub the parts kit for that is 5303937187 now on washers with rubber boots its recommend that you shut the door with a little force to make sure it closes tight against the boot sorry about the letters they came with the part number you might want to call kenmore parts to ask about the boot kit if i was there i could tell you but it looks like a frigidaire to me
Mar 12, 2008 | Kenmore 44072 Front Load Washer
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
212 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
