Question about Frigidaire FDE647RF Dryer
Drum makes noise after I unscrewed the screws inside the machine.
I have de frigidaire dryer model (FDEC647RFS1) or (FDE647RFS1). Unfortunately, I wanted to clean the lint accumulated behind the drum and I unscrewed the screws of the drum thinking that I could vacuum the lint. Then, the part back of the drum fell and I had a lot of trouble to reajust the hole of the screws to put it back together again. Now the drum rolls well but there is a noise (a bit like a loud whistle) when the dryer is working. What could have happened? How can I repair my mistake? Thank you Celine from Montreal Quebec
  • clemo131 May 23, 2009
    Hi Guru,
    Thank you for your fast answer. You were telling me: You will have to remove the drum from the front and replace the drum support cup kit.
    How can I do that ?
    Thank's again.
    Celine
  • Frigidaire Master
  • 3,361 Answers
Posted on May 23, 2009
  • steve
    steve May 23, 2009
    Take a putty knife and press in on the tabs at the right and left corners where the lid meets the front panel. Lift the lid to the rear. Remove 2 screws on the right and left inside frame near the front panel. Disconnect the door switch wires and remove the front panel.Remove the belt from the motor. Use the belt to pull up on the rear of the drum.
    Remove the drum from the cabinet.
    The rear drum support cup is attached to the rear of the cabinet.
    The rear drum support ball is attached to the drum. These parts come as a kit to be replaced.
SCREECHING DRYER
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
The glides on drum worn and making metal to metal contact.
CHECK FOR LOOSE BELLOES inside the drum
Apr 11, 2014 | Frigidaire Washing Machines
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Thumping noise when drum makes a full revolution
Open the cabinet and look at the screws that hold the vane (paddles) on inside the drum. They will come loose and make the noise you described.
Dec 26, 2010 | Frigidaire FER641FS Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
Our Frigidaire FEX831CS dryer started making funny noises and has completely stopped. We hit the start button now and all we hear is is humming in the machine. We checked the belt and it does not seem...
Check the inside rear of the drum for the three screws in a triangle closest to the center.
If these screws come out the drum rolls off center and the motor can no longer drive it.
Good Luck
Quentin
Oct 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
Electrolux FGX831FS1 dryer drum, only spins one way manually
Check inside the drum to make sure the three screws in a triangle in the rear center are all there, if they fall out the drum goes off center and the motor can no longer drive it.
This model has no rollers, the front of the drum has plastic glides mounted on the front of the drum that ride on teflon impregnated pads that are glued around the door.
The rear is supported by a steel ball screwed to the rear of the drum (the 3 screws that I think are causing your troubles) that rides in a plastic saddle screwed to the rear of the machine.
If the excess drum movement is only up and down you should replace the front glide system.
Good Luck
Quentin
Apr 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
Access to burner on Frigidaire Affinity AGQ6000 series dryer
you do have to pull out the unit and use the rear access to unscrew those screws accessable from the inside.
Feb 18, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
LG DRYER MAKING CLUNKING NOISE
Clunking could be from bad rollers or cracked drum. Check the drum seam for a crack. If its the rollers you can do the same thing as drum replacement only order the rollers. I got my parts from Sears parts. The below is for a 2514 but should be close for yours.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Feb 10, 2009 | LG DLE2515S Gas Dryer
Dryers Logo
217 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
