Question about Canon PIXMA MX850 Multifunction Printer
Prints light pixma ip4000 prints light, formerly worked OK
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    check cartridges they are short of ink
    Problem Solver:
  • 11 Answers
When your printer begins to print light, that is usually an indication of the ink running low. Replace your ink cartridge and see if that helps.
Posted on May 23, 2009
Pixma iP4000 - reddish tint prints
Run the self cleaning head function, to clean ink jets(heads).
May 13, 2014 | Canon PIXMA iP4000 InkJet Photo Printer
Tip
How to unclog a clogged print head on the Canon...
Using a cotton swap dip into some plain water and then drop a few drops of water onto the outlet of the ink cartridge [you will have to remove the ink cartridge and turn it upside down].
Also while the ink cartridge is still removed, drop a few drops of water onto the inlet orifice into which the ink goes. The orifice of the ink cartridge sits right on top of the inlet to the print head when the ink cartridge is fully installed.
After putting the water drops onto the ink cartridge and onto the inlet orifice of the print head, I did the 'clean' procedure as listed in the "Canon PIXMA iP4000 Properties" of the program on my PC. Then I did the deep clean procedure. After that I printed the print pattern and found that this technique worked quite well -- since before I had tried isopropyl alcohol which didn't work to unclogged these print heads.
When I had the blue print head get clogged [on my Canon iP4000 Pixma printer] and I tried this method. It worked immediately.
I hope it works for you too.
God be with you!
engineer550.
on Jun 16, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
I am getting 5 flashing yellow lights. As far asI can tell from the manual it appears I will need a new print head. Can it be cleaned or is it done?
Yes, that is a printhead fail. Printheads are almost as expensive as a new printer for the Pixma iP4000. You can find the printhead on eBay, runs $50-$80. Better to put that money towards a newer printer. You can also look for scrapped or damaged i860, iP4000, MP780, MP760, MP750 model printers and salvage the printhead from those.
Mar 18, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4000 has stopped printing. It is going through the motions but the paper is coming out blank with nothing on it.
Hi
If you have lots of flashing error lights or electrical problems then it is likely to be electrical.
However, if like most... and your Canon PIXMA iP4000 InkJet Photo Printer has just been left unused for some time? You probably have an ink clog on the cyan and magenta.
Or possibly a faulty cartridge.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP andremoving those horrible white lines which usually appear in prints whendried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use the Magic Inkjet Flush kit to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Nov 23, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Cleaning/replacement of Nozzles of Pixma iP4000 Canon Printer
My Canon Primax ip4000 has stopped printing blue. I've tried deep cleaning and when I print a test page the blue 6c does not appear. Any ideas what the problem could be?
Nov 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Jun 04, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MX850 Multifunction Printer Logo
78 people viewed this question
old marine
old marine
