Question about Procom ML300EBC Heater
Pilot won't ignite
I have a ML300EBC Procom. I hooked it up and everything electrical worked but there seems to be no gas(propane) getting to the pilot. There is no smell, it sparks but nothing. Yes tank is just filled and turned on. Could the internal regulator be damaged. It is brand new never used unit. Help!
Thank you
  • Anonymous Mar 10, 2008
    My heater was dusty so I took it and blew it out with the air compressor, now I can't get it to light the pilot.
For SBP12,
It will take some time for the gas to get to the unit, just turn it on and wait. It might take 5 to 10 minutes to fill the line with gas.
Posted on Oct 22, 2008
Hooked up roper dryer and it's propane everything seems to be hooked up right but won't get hot or even heat up. This is first time ever having to use propane. Any idea what it might be or could have...
1.is the pilot light lite burning.
2. if pilot light light is on ,does the blue flame of the pilot light touch and heat up the thermocouple.
the dryer will not turn on the heat if the pilot flame does not touch and heat up the thermocouple.
3 is the dryer plugged in to the electricity.
4. is the dryer actually getting electricity.
If the dryer has electricity and the pilot flame is touching the thermocouple, then try buying and installing a new thermocouple.
****have you purged the air out of the gas lines so that the dryer is actually geting pure propaine and not just air getting pushed ahead of the propaine.
how old is your dryer, if new, warranty service will trouble shoot & repair for free.
you need to tell us more so that we have some facts to work with. vagueness does not cut it.
Oct 09, 2013 | Dryers
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
Procom propane heater will light the pilot but not the burner
the pilot and clean the injector and see if this is clear then try it , you will need a pressure gauge to check the gas pressure ,
Feb 03, 2010 | Heating & Cooling
ML150HPA model-the pilot flame dances off its base, allowing Thermocouple to cool and shut heater off.
You need to check the gas psi . going to the unit .Natural gas psi to the valve should be 5--7.5" of wc. propane gas psi should be 11" wc.
Dec 21, 2009 | Procom ML300EBC Heater
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Heater runs 2 min. shuts off
Aim the pilot flame harder down the thermocople.
Willis
Feb 11, 2008 | Procom ML300EBC Heater
Pilot light seems to high
there may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
Oct 24, 2007 | Procom ML300EBC Heater
Procom ML300EBC Heater Logo
203 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
