Question about Canon MultiPASS F60 All-In-One InkJet Printer
Blank pages I have installed new ink and have cleaned the printhead as instructed on my computer and I am still having blank copies. Do I need a new printhead and if so can I install it? Thanks
  • shoreman1058 Oct 20, 2007
    We tried what you suggested, but I am still getting blank pages.  Thanks so much for trying.  Looks like a repairman is in my future.
I dont really know what the problem is but you may not have to replace the printer head. all u have to do is tale it out see if the the printer head is dry or not. if so set it in water for about an hour and put it back in
Posted on Oct 20, 2007
My kodak esp 6150 prints blank pages. I bought new ink and new print head and still prints and copies blank. Kodak support says I need new printer but there has to be a way to fix it. It was fine one day...
if u can't clean the print head and there is ink in the cartridge, then a new printer is in the plan.
try cleaning head by placing a pad soaked in alcohol (not Tequila) on the head for a while then gently wiping it clean. If u can remove other parts that r full of ink to clean them do that - careful that ink will get everywhere.
Dec 09, 2014 | Kodak ESP Office Equipment & Supplies
Why am i getting blank copies from my printer
The chances are good that what U need to do is a printhead cleaning. On the printer if it has a LCD screen scroll through the menus and look for Maintenance or tools and then look for printhead cleaning . It can also be done through the software by going to the top left hand corner of the page U are trying to print and click on the button or File scroll down to print and click on that and that brings up a box with your printer name in it and beside that is a box called properties and look for maintenance or tools there. After the printhead cleaning it will ask if U want to print a test page - say yes if that page looks good -problem solved but it will probably take a few cleanings if U R getting blank pages now. Warning repeated cleanings use a lot of ink so only do what you need to. If after several cleanings U are still getting blank pages U might need to replace the printhead
Aug 03, 2014 | HP Business InkJet 2800 Printer
Hp officejet pro blank pages with full ink cartridges.
Try reinstalling all of the printer software. If that does not do it then something is wrong with the printhead itself, specifically the area that controls the flow and metering of the black ink.
Aug 03, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
I replaced the black ink cartidge and made a few copies then blank lines began to appear . So I cleaned the printheads and still the same copy problem Then I went the next step and removed the printheads...
when u say u see black lines when making a copy after installing a new ink it is possible that the scanner glass and scanner lid need to be cleaned and try to check if this printer has a scanner strip--it is located at the automatic doc. feeder--clean it as well then try to make a copy one more time
Apr 02, 2010 | HP Officejet 9110 All-In-One InkJet...
I have been trying to get my 5300 kodsk printer to
Try to print a picture in from the computer if it works then the printhead needs replacement (Call Kodak support).
If while printing picture still a black sheet is thrown out. Delete the Kodak printer icon from control panel > Printer and faxes . Restart the computer and re-connect the USB.
If these does'nt work try to COPY a pictue using only the printer, still u get a blank page try to install the ink cartridges and the printhead. Is still blank prints. The printer will be replaced
Jan 21, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Canon MX850. Print blank after ink changes. The black ink, PGBK-5, ran out so I replaced it with a cheap generic ink tank. But it didn't work, nothing print, not even color copy. I thought the ink is bad...
That is a common problem on all Canon printers, the purge assembly on the right where the printhead parks, has a pump inside and hoses that go to the filters and ink absorbers. When that unit goes out you need a replacement. A job best done in a shop. When the printhead is not cleaned and primed properly you get blank pages no matter how full the inks are.
Dec 24, 2009 | Canon PIXMA MX850 Multifunction Printer
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
how did the paper exit inot your pritner? Its act like printing or its fast and smooth? If its act like printing you just need to clean the printhead or if cleaning printhead did not solve the issue you need a printhead replacement, Now if the paper exit in your printer fast and smooth you need to replace the printer and the printhead., You need to call kodak for support toll free 1 800 421 6699 ext 05., The troubleshooting may apply also for blank documents using word or any other application.,
Nov 16, 2009 | Kodak ESP 5 Printer
Communicates with XP-PC, makes all the moves and sounds- nothing prints
Hi, Hope this helps
<object width="425" height="344"><param name="movie" value=""></param><param name="allowFullScreen" value="true"></param><embed src="" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Oct 11, 2008 | Epson Stylus CX5800F All-In-One InkJet...
New printer, blank pages
To remove the printhead:
Ensure that the printer is on and open the printheadcover.
----The printhead holder will move to the center.
Press for some seconds the resume/paperfeed button.
----The printhead holder will move a little to the right.
Press and lift the tiny grey handle now visible at the left and in front of the printhead holder, now you can remove the printhead.
Sep 23, 2007 | Canon i80 InkJet Printer
Canon MultiPASS F60 All-In-One InkJet Printer Logo
old marine
old marine
