Computers & Internet Logo
Posted on May 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ActiveX install bar not appearing
When I click to "Play Now" on Majohng Deluxe Gardens...I am told I need to intall a new component for ActiveX, but there is no yellow bar for me to click to install. It is saying I need the "Pogo Web Launcher" in order to play the game. How do I get that? HELP!!!
Anonymous
Level 3:
President:
  • Master 1,179 Answers
  • Posted on May 23, 2009
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422734
Points
3751
Go to pogo.com and they should have the Web launcher available for free download. Hope this helps.
1helpful
When try open a downloaded software, a window appears with "ActivX componant can't create object
Most likely the website that you are trying to download the software need an ActiveX plug ins. If you see an information bar below the adrress bar that looks like this.horhe.jpg Please allow the add on to install.
If the instruction above doesn't work, please try to reset the browser.
1. click on Tools
2. Select on Internet option
3. Click on Advanced tab
4. On the bottom right corner click on Reset.
2helpful
How to install flash player
Thanks for taking time to contact Fix Ya
1. Kindly follow this link to download the latest versions of adobe flash player http://www.adobe.com/support/flashplayer/downloads.html
2. Click on this link
Get the latest version 3. Click on Download now to get the latest version of adobe flash player
5.Follow these simple steps
Wait for the information bar to appear.
Click on the information bar, and then select Install ActiveX Control.
Click Install.
1helpful
We need to play games but the computer said that we have to install activeX pls help us!
There should be a yellow bar that appears at the top of the browser window when you visit the website for the games. Watch for it and click on it. Then choose "install activeX control" and let it do it's thing. Be careful though, it's a powerful tool and can be used maliciously. So make sure the website that's requesting this is legit. Good luck.
When i try to download java for my window vista it says click yellow bar which does not appear and when i try to download java manually it says it is there but it doesn't work so i am havin 2 problems...
Lets take this in two approaches: (1) The yellow bar it refers to is the one that appears below the links bar at the top of your web browser. It will tell you that something is trying to install on your machine..click here for options. Click on the yellow bar and the option to install ActiveX control or to download the file should appear.
(2) Head to www.java.com. Click on the Download Java button. See approach number one above for the rest.
My message keeps saying new flash player required but I cannot update it
click on the Tools icon in your browser... Choost Internet Options.. from there , choose the Security tab, click on the Custom button, and scroll down to the ActiveX Controls... look there for Download Signed ActiveX Controls... Choose to Prompt or Allow..( Enable)... then try messenger
Help me please
activeX is already installed. it wants you to install it using activeX. do this by clicking the yellow-bar on top and pressing install using activeX.
Adobe
First of all check if you are in Admin mode.If so
When Internet Explorer 5 on Windows encounters a request from a page to download a new ActiveX control, an option is provided to allow the user to prevent the specified ActiveX control from ever installing in the future. If this option, called Install on Demand, is selected when you encounter Flash Player ActiveX controls, future installation attempts of these controls will fail.
If you are unable to install Flash Player due to this feature, first run an executable that rectifies the problem and then install the Flash Player.
Is it enough?
Please rate it
2answers
Installing active x control
it appears at the top of your web page on certin pages you get it at the top off microsoft update page a yellow bar appears just click on it and install active x this should sort you out
How do i uninstall microsoft active x control on my pc?
Internet Explorer 3.0, 3.01, and 3.02 loadTOCNode(2, 'moreinformation'); 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. Click Start, click Run, type the following line in the Open box, and then click OK: regsvr32 drive:\windows\occache\filename.ocx /uNOTE: drive is the drive letter on which the Windows folder is located, windows is the name of the folder in which Windows is installed, and filename.ocx is the ActiveX control you want to remove.
NOTE: If you do not know the file name of the ActiveX control (.ocx) you want to remove, you may be able to determine the file name by viewing the Hypertext Markup Language (HTML) source of a Web page that installs or uses the ActiveX control. To view the HTML source of a Web page, right-click an empty area of the Web page, and then click View Source. 4. In Windows Explorer or Windows NT Explorer, click the .ocx file in the Windows\Occache folder, and then click Delete on the File menu.Occache is the name of the folder where ActiveX controls are installed in all versions of Internet Explorer 3.x. The Regsvr32.exe file is installed by Internet Explorer and can be used to register and remove registry entries for ActiveX controls.
Internet Explorer 4.x or Later (All Platforms) loadTOCNode(2, 'moreinformation'); Internet Explorer 4.x or later, include the Occache.dll file, which is used to enumerate, update, and safely uninstall ActiveX controls using a "shell folder." 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. In Windows Explorer or Windows NT Explorer, double-click the Windows\Downloaded Program Files folder or the Winnt\Downloaded Program Files folder, right-click the ActiveX control you want to remove, and then click Remove. 4. When you are prompted to remove the ActiveX control, click Yes.IMPORTANT: The following ActiveX controls should not be removed if you are running Internet Explorer 4.0: • DirectAnimation Java Classes • Internet Explorer Classes for Java • Microsoft XML Parser for Java • Win32 ClassesInternet Explorer 5.0 or later does not require these components in the Downloaded Program Files files.
Error Messages Removing ActiveX Controls loadTOCNode(2, 'moreinformation'); When you attempt to remove an ActiveX control using an Occache shell folder, you may receive one of the following messages: • Share Violation These program files are currently being used by one or more programs. Please close some programs, and try again. You may need to restart Windows. • Component Removal About to remove a Windows system DLL: (<path\filename>). Okay to delete?Share Violation:
This message occurs if the ActiveX control you are trying to remove is currently loaded in memory by Internet Explorer or the Active Desktop component.
To resolve this error message, follow these steps: 1. Close all open Internet Explorer windows. 2. Disable the Active Desktop. To do so, right-click an empty area on the desktop, point to Active Desktop, and then click View As Web Page to clear the check mark. 3. Remove the ActiveX control by following the steps in the "Internet Explorer 4.0 or Later" section earlier in this article.
NOTE: You may need to restart Windows before you remove the ActiveX Control.Component Removal:
This message occurs only in versions of Internet Explorer 4 prior to 4.01 Service Pack 1 (SP1) when the ActiveX control you are removing installed files into a folder other than a registered Occache folder (for example, Windows\System or Winnt\System32). Occache cannot always determine if those files are shared by their programs.
If you are certain the file or files displayed in the message are not being used by Windows or another program, click Yes. Otherwise, click No.
NOTE: In Internet Explorer 4.01 SP1 and later, Occache does not remove (or prompt you to remove) dependent files outside of a registered Occache folder.
Support for Multiple Occache Folders loadTOCNode(2, 'moreinformation'); Internet Explorer 4.0 and later supports multiple Occache folders. The list of Occache folders is located in the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ActiveX CacheBy default, Internet Explorer 4.0 and later uses the Windows\Downloaded Program Files or Winnt\Downloaded Program Files folder. If you upgraded from Internet Explorer 3.x, both an Occache and Downloaded Program Files folder may exist. In this case, all new ActiveX controls are installed in the Downloaded Program Files folder, but previously installed ActiveX controls still work in the Occache folder. When you open the Occache or Downloaded Program Files folder in Windows Explorer, Windows NT Explorer, or My Computer, all ActiveX controls are displayed regardless of the folder in which the ActiveX control's files are located. In this case, the following string values appear in the registry key: "0"="C:\\WINDOWS\\OCCACHE" "1"="C:\\WINDOWS\\Downloaded Program Files" For additional information about ActiveX controls, please see the following article in the Microsoft Knowledge Base: 154544 (http://support.microsoft.com/kb/154544/EN-US/) Description of ActiveX Technologies For information about how Internet Explorer downloads ActiveX controls if a conflict occurs (for example, if the file already exists), please see the following article in the Microsoft Knowledge Base:
HOPE THIS HELPS
Good Luck
Grand Canyon Tech
Grand Canyon Tech
