Question about Poulan Weedeater/Electric Trimmer 4.1 Amp
Wont start My electric weedeater twist n edge wont start. Pull the trigger and nothing happens.
    New Friend:
    Problem Solver:
  • 5 Answers
Same problem, try checking the connections to the motor one could be lose going to the graphite blocks. Just put some cloth tape on it and put it in as far as it will go!
Posted on Jun 26, 2013
  • 4 Answers
Try and change the solenoid!!
Posted on May 29, 2009
Repair mig welder
Control circuit failure or blown fuse on low voltage power supply. Look for 24VAC transformer. If that is OK follow to the trigger contactor and see if it is disconnected, burnt, etc.
Aug 28, 2014 | Welding Tools
Pull trigger and nothing happens
Are you sure you have the safety key attached. Make sure power is on at receptacle.
Feb 09, 2014 | Ridgid Ms1065lza Saw 10-inch Compound...
Poulan pro weedeater 330 runs but no power. boggs downs when full trigger pull
remove the muffler and try it if ok open the muffler and clean out the carbon from the screen
Apr 06, 2012 | Poulan Garden
My chainsaw wont start. electric souce is good, but nothing happens when you press the trigger.
Check the chainbrake is fully pulled back to the top handle, many electric saws have a micro switch to prevent the saw from running with the brake on.
Jul 16, 2011 | Mcculloch 16" Electric Chain Saw Mcc3516f
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Weedeater FLSST25 FeatherLite 17-Inch 25cc 2-Cycle Gas Powered Straight Shaft String Trimmer won't start
remove the air filter and introduce a little fuel into the intake, attempt to start it with a few pulls, if it pops off a little you have a few system issue, if nothing happens remove the spark plug and observe whether it is damp, oily, black, light gray or nice and clean, if damp, you got too much gas, try drying it out and have a go again this time without any choke. If dry and clean or light grey, not enough fuel. check the plug for spark, making sure the ignition is on, if no spark, you have likely got a coil or switch problem, if you pull the plug and it is wet, and totally gray or brown and it sparks, you may have internal engine issues.
May 24, 2010 | Garden
Trying to replace the line in weedeater Twist/Edgs RTE 115c. I can not get the line to feed into the spool. How is this done?
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Oct 25, 2009 | Electric Garden
Twist and Edge Weedeater will not start.
You will have to check all the hoses and carb gaskets/diaphrgms. Get the model # off you carb and buy a repair kit from http://www.m-and-d.com/STENS-ZAMA_repair_parts.html
replace the fuel hoses. Be careful to put them back in the correct configuration.
Aug 04, 2009 | Poulan 12" Electric Twist N Edge Plus...
How do i replace a spool on the weedeater xt110. I cannot seem to get the spool to release and I do not have the owner's manual.
Just line up the two arrows across from each other to those on the the spool housing on the bottom of the spool. Then grip the bump knob and pull straight out. It takes a good grip and some force, but it usually gives way.
Jul 14, 2009 | Poulan 12" Electric Twist N Edge Plus...
Poulan Weedeater/Electric Trimmer 4.1 Amp Logo
385 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
