Question about GE WBXR3100B Top Load Washer
Loud noise during spin Whirlpool Estate TAWS 800 JQl
My Whirlpool Estate TAWS 800 JQl washer makesa banging sound almost as if the "load is unbalanced" during every spin cycle. There is no odor though. It is very loud and sounds as if a train is going through the house. No other symptoms...wash goes though complete cycle. Any suggestions?
  • 725 Answers
SOURCE: spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Posted on Dec 23, 2008
  • 379 Answers
As you've already had a new motor fitted, it could be something is preventing the drum from rotating freely. This may then be causing the drive belt to slip on either the motor pulley or the drum pulley. This would also overload the motor and the motor control electronics would shut down to protect everything.
If not, then it is most likley a fault in the motor control electronics. I am not familiar with this exact model, but the motor control electronics are quite often on a separate circuit board mounted somewhere inside the machine where there is a good flow of air. Even when working normally, the motor control electronics have to handle a lot of power and therefore get hot. However, they should never get so hot as to give a burning smell.
It isnt possible to check the motor control board just by looking at it, so unless you have electronics knowledge, you may have to risk getting a new board and hoping that fixes it. Otherwise it's time to call an engineer.
Posted on Nov 02, 2009
  • 3740 Answers
SOURCE: loud banging noise during washing cycle. Sounds
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
This part is the most likely cause of the noise.
Thanks for using FixYa.
Posted on Mar 07, 2010
  • 618 Answers
SOURCE: the washer shakes uncontrollably during
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Posted on Nov 17, 2010
  • 447 Answers
SOURCE: estate washer bangs and shakes
has it been releveled? if it has then it sounds like there is a problem with the counter weight or suporting springs/bracket the only way to tell is to check inside the machine.
Posted on Jul 28, 2011
Estate Washer Model TAWX700JQ0 Washer fills when started... Does not Wash, Spin, Rinse, or Drain. during the wash cycle the water fill solenoid sounds like it is energized but no water is entering the...
You say washer fills and then you say no water is entering the washer?? Burning smell is most likely motor overheating due to maybe something stuck in drain Pump.
Nov 14, 2017 | Estate TAWX700JQ Top Load Washer
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Whirlpool Estate etw4300sq squeaks during spin
Nov 08, 2009 | Crosley CW5000 Front Load Washer
During spin cycle it becomes unbalanced and it beeps and stops
It sounds like the sensing arm of the out of balance switch assembly is wrongly set. Get the guy back to do the job properly at no charge!
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
GE WBXR3100B Top Load Washer Logo
117 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
