Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
Mitsubishi ws65315 tv
Powers on then immediately shuts off. It just started today 5/23. Purchased 3 yrs ago at Best Buy Any suugestions and recommendations. I live in St. augustine florida.
  • urbies May 11, 2010
    the code is 22
  • Sonny Berry
    Sonny Berry Feb 16, 2013
    ok the 22 error is short protect which usually means the convergence has failed. Your model is the V24 chassis and you can get the repair kit called the V23 and V24 Chassis convergence components from the following linkhttp://tvrepairworld.com/mitsubishi_repa...
  • Mitsubishi Master
  • 8,617 Answers
Try accessing the self diagnosis feature by pressing both the menu and device/input button in together on the front of the set and hold for 6 seconds to see if the led will blink a two digit code such as two blinks slight pause then another series of blinks to indicate the second number then let me know the code and I will assist you.
Posted on May 23, 2009
  • 1 more comment
  • greg_berry31 Nov 25, 2010
    Mine is doing the same thing. After the 2 blinks, it blinked again twice.
  • Robert McDonough Feb 15, 2013
    Mine too. 2 blinks, then to blink again. Can you help?
  • Sonny Berry
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
User manual for mitsubishi TV model ws65315
here it is :
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55315.pdf
SD TECH
Oct 31, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Powers off red light starts blinking
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
Mar 23, 2010 | Mitsubishi WD-Y657 65" HDTV
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Sep 30, 2009 | Mitsubishi WD-57734 57" HDTV
3rd lamp purchased within 2 yrs
There is a slight chance that you might have an issue with a defective ballast, I mean 3 lamps in 2 years, it's too much. The best way to go here is replacing the ballast, that might solve the issue.
Jul 25, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Tv shuts off, red status indicator lamp flashes.
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Mitsubishi WT-A42 projection 42" HD1080 series
It sounds like your regulator circuit is defective. Not an expensive repair, maybe $200.or a little more.
Apr 08, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
398 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
