Question about Samsung Syncmaster 17" 720N Monitor
Picture size problem
Hi ! I Have bought a monitor Samsung 720N and I do not know how to reduce vertical its picture. It is not visible up and down. Adam
    Sergeant:
    Champion:
  • 212 Answers
Click start,control panel,display,settings and set your screen resolution to what you need
Posted on May 23, 2009
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
How do I install a samsung syncmaster 720n monitor without a disk
Hi, if you click on the below link -
Samsung Syncmaster 720n
it will take you to Samsungs site where you can download both the usermanual and the driver you will need to install. To get to the drivers, wait for the page to finish loading, then underneath the word Download on the downloads tab there are two options, Manuals and Driver. Click on the word Driver and below will appear the driver - just click on the EXE picture under the word File to download and install.
Thanks, if this solution helps please rate :)
Feb 19, 2011 | Computers & Internet
Have samsung syncmaster 720n monitor. adjustment menu blinks on/off. how to stop?
Trying the hold down power button for count of ten (did count of twenty just to make sure) didn't work. Menu came back up. Will try unplugging control chip next (this fix doesn't make sense to me ) will see if monitor will work without chip>
Aug 13, 2010 | Samsung SyncMaster 720N Monitor
My lcd samsung sync master 720n horizantaliy one line on screen
Hi
Please try the following
1) Degauss the monitor - this can be done by using the menu system on the monitor scroll through the options and click/highlight the degauss option
2) Change the VGA lead going from the monitor to the PC
3) Ensure you have no unshielded mangnetic sources near by like speakers etc
If after trying the above the fault is still apparent then unfortunatley your monitor is at fault and will need to be repaired
If this has been useful please leave postive feedback/vote
Feb 12, 2010 | Samsung SyncMaster 720N Monitor
Will not power up
Hi there.
Have you checked the powersource? Is the transformer working?
Is the cable from the wall socket to the transformer broken? Is the cable from the transformer to the screen broken?
Is the plug on the same cable damaged?
Is the transformer the right size( voltage)
Is the polarity on the screen plug right?
Is the screen actually working?
Iceman.
Nov 04, 2009 | Samsung SyncMaster 720N Monitor
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
Vertical size
LCD monitors auto adjust and use a fixed resolution. It's impossible to reduce the vertical scan. The only what I could think of is to specify a widescreen resolution if the monitor is not widescreen and this may only work if you are connected by DVI cable. Sorry!
Jan 16, 2008 | Sony SDM-X95KB (Black) 19" LCD Monitor
Samsung Syncmaster 17" 720N Monitor Logo
110 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
