Question about Dryers
The belt is broken. How do I install a new belt.
Whirpool electric dryer, Model # LER6620PQ1 The belt is broken. How do I install a new belt.
    President:
  • 1,136 Answers
Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off.
There should be instructions that came with the belt. I will try and explain how this goes on. The idler pulley fits in a slot right in front of the motor. Put the belt over the drum with ribs touching drum. Now, thread the belt through the idler pulley wheel and bracket and set the belt on the motor pulley. The ribs should rest in the grooves on the motor pulley.
I hope this helps you. If I can assist you further, please let me know. Please rate me performance so that others as well as myself will know how I am doing.
Thanks
Vic
Posted on May 23, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My dryer tumbler will not turn however the light turns on
    You may have a broken belt.
    Pop the top. you will see the belt immediately (or not) If you see it, (it is about 1/4 wide) is it tight or lose? If you dont see the belt, it has probably broken and fallen to the floor of the machine.
    Remove the front to replace it.
    Find the parts at a appliance parts store or visit repairclinic.com
    I hope you find this answer to be of value
    a
    Oct 02, 2009 | Dryers
    Drum will not turn
    YOUR BELT ON YOUR DRYER IS BROKEN. THAT IS WHY YOUR DRUM WON'T SPIN. YOU CAN BUY A NEW BELT FOR YOUR DRYER AT ANY PLACE THAT SELLS APPLIANCES.
    RODNEY
    May 15, 2009 | Estate TEDS740JQ Electric Dryer
    Need to get to belt on my whirpool dryer
    TAKE FRONT OF DRYER OFF PLACE BELT OVER TUB @ THEN OVER THE PULLEYS MAKING A FIGURE 8 LET ME KNOW IF YOU HAVE ANY PROBLEMS
    Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
    Dryer won't rotate stuck on fluff
    one of two things has happened the belt is broken or the electric motor has failed
    Apr 13, 2009 | Whirlpool ET8CHEXSQ Dryer
    Whirpool Dryer Electric
    broken belt is probable. If not, check the door switch operation. If that is ok, check voltage out of the timer to the motor.
    Oct 26, 2008 | Whirlpool Dryers
    Dryer tumbler will not turn however the light in the dryer will come on. I have an electric Whirpool Model #SEDS800JQ0 / Serial #MK50005327 Thanks for any suggestions you can offer me. Xavier
    Does it turn on and run with out the drum turning around. if so you most likely have a broken belt, if just the light comes on and nothing else happens your thermal fuse is most likely bad.
    Feb 27, 2008 | Dryers
    Help me install belt on electric dryer
    need model and brand of drier
    Dec 30, 2007 | Dryers
    Dryers Logo
    108 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
