Question about Kenmore 44102 Front Load Washer
Have to replace bellows on kenmore frontloader 44142 bought in 04
Leaking, bought replacement bellows. need help with installment
    Sergeant:
    Novelist:
  • 176 Answers
Not too hard, just need a couple of tools and an hour or so. First, open the door. Next you need a thin bladed Richard brand knife model #S-12 or a razor blade and a flat thin screw driver. The seal has been glued on and you need to find a place that you can slip the screw driver between the door and the seal. Jently pull as much of the seal away from the machine as you can. Once you find a glued piece slip the knife bewteen the seal and the machine to cut the glue. It is good glue so it will take some time to do this all of the way around the door opening. Once all of the glue has been cut, undo the plastic water spout clamp, reach inside of the machine and grab the seal by the top of the wash tub. Pull down and out at the same time and the seal will come out with a little effort but watch out for the tension spring. The spring has some tension and could come out rather quick so do not have your head by the door when doing this step. This concludes the removal and since you bought a new seal, all that is neccessary is to clean off all of the glue residue on the machine and the years of grime on the tub where the seal goes. Clean these areas very well and it will pay dividends later.
To install the new seal look on the wash tub at the top and bottom and there should be an arrow cast into the plastic in one of the locations. Line up the arrow on the rubber seal (search for it) with the one on the wash tub. Carefully instal the seal by having a finger in the seal groove and hooking the seal over and under the wash tub lip. Do not let the arrow slip to a new location as you are doing this. Once the seal is in place double check to make sure that the seal is properly installed. Now gently push the seal into the wash tub so that you have access to the outer lip of the wash tub where the tension spring goes. 2 people are required for the next step. One person will place and hold the spring in the groove and another person will stretch and feed the spring in both directions around the spring groove. Take your time and do not loose your cool with this step. If you need to use non pionted or sharp tools to assist, what ever works is fine. Once the spring is in place you need to reglue the door seal to the machine. I use black RTV silicone from your local auto parts store. Place some glue into the channel and pull the gasket out from inside the machine. Slip the seal over the lip all of the way around the door opening and remove any excess silicone. Let this cure over night before using the machine. That is the end and the door seal is replaced.
Posted on May 24, 2009
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How remove Kenmore frontload basket from rear shell?
this is a big job and prob spendy if not under a warranty......
the outer tubs are connected by metal fasteners which need to be removed by a flat screwdiver mark the old fron outer basket with a marker so u can replace those clips in the same manner..........to get acess to the tubs turn power off and remove top, remove back panel, remove front as well console bottom panel etc,,, disconnect all componets,bellows gasket ,connection wires, tubes, remove motor, undo bottom pump tube, remove belt and remove back bolt holding on pulley, get two people and remove tub out front when completed disasseblying all necessary pieces.. once tub out then remove those metal fasteners and set aside front tube reinstall onto new rear/inner rear tubs... hope this helps i might have forget some things actually i know i did this is a complicated process hope this helps let me know
Apr 20, 2010 | Kenmore Elite 45986 Front Load Washer
How do I stop my Kenmore front loader from leaking around the door. I have a Kenmore HE 2plus front loader
If this is a Kenmore FRONT LOADER you need to remove the lower toe panel directly below the door to inspect the cabinet interior for the source of your leak. The following link explains:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of leaks on a front loader is the rubber door bellow. The bellow can develop cracks, rips or tears with age and needs to replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please let me know so that I may be able to provide you with better assistance. I hope this helps you.
Jan 31, 2010 | Kenmore HE2 Plus Front Load Washer
KENMORE FRONTLOAD WASHER Model# 41741052000
very common for the tub seal to leak - or bellow to be ripped.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Kenmore 44102 Front Load Washer
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking washer
Replace the valve, or if new, have them do it. You are sure it is the valve and not where the hot warter hose attaches? Confirm by hooking up hot water under preasure to see if that seals itself.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Oct 27, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
209 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
