Question about Whirlpool Dishwashers
Ineed an installation manual for a Whirpool Model DU806cwdb5 dish
I just bought a used dishwasher and I need refreshed on how to install it.
  • George Jones May 11, 2010
    i need a name and a model # to help
  • 909 Answers
You will have 2 pipes and a flex, Or 1 pipe 1 flex and a connection for a inlet pipe.
Connect the gray, larger pipe to the waste out let(drop in a stack or connect to a "spiggot", then connect the smaller pipe to the water inlet, you can usually connect to the washing machines inlet using a "y" piece, remembering to shut off the water before disconnecting. Then plug in the flex and away you go.(remembering to turn the water back on and a quick check for any leaks)
Posted on May 23, 2009
The dryer for the dishes on the whirpool doesn't come on
My God? If you had it installed yesterday.....1) read the manual. 2) try again and 3) Call store you bought it from and/or Whirlpool for warranty Service Call.
Why if you bought something new would you post here for a obvious operation or Warranty performance issue?
Sep 11, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
The dishwasher doesn't clean the dishes--at all. It's not like I get a sandy residue; the dirty dishes look exactly the same after the dishwasher has run as they did when I loaded them. It is a brand new...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 01, 2011 | Dishwashers
Maytag dishwasher mdbh950aws does not clean dishes completely leaves residue on glasses and plates. using normal cycle. does any lines or filters need cleaning? followed all recomendations in manual.
Dishwasher
How to Buy
heatman101
Dec 08, 2010 | Maytag 24 in. MDBH950AWS Built-in...
I'm trying to install a new mount in my whirpool dishwasher. The spray arm does not turn freely and is hitting the dish basket.
The screw types rarely give problems - so I'm presuming it's the clip type with plastic prongs.
First make sure the replacement part is the same as the old. It should press - fit with a click when in position.
Make sure the back supply tube is in the correct position and not lifted out too much.
Aug 20, 2009 | Dishwashers
Whirpool dishwasher does not go into wash cycle
you will need to replace the control bd. if it is not washing. I think that it is probably just filling and not starting the washing process and this would be a bad sump/mtr. assy.
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirpool dishwasher
Ours does the same thing. I have been suspicious that it is the melting plastic stuff used in the dishwasher tabs that the wife uses.
Let me know if you use that same tab to wash you dishes.
We dont have any problem with the stuff getting on dishes (and we use all white diner type dishes.).
Jan 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Does Not Drain ... We Don't even Use it
I know you're probably not needing this anymore, but for anyone else who has a similar problem...
Your dishwasher is installed wrong. You should never get water back into it from washing dishes in the sink. (of course - unless it is installed wrong) The "drain air gap" that you should see on top of your sink is to prevent water from back-flowing into your dishwasher. Sometimes plumbers put in a "stand pipe" (a pipe that goes way up in your sink cabinet underneath, but just is actually the pipe from the dishwasher and they loop it up higher than the bottom of the sink level in the cabinet. That way if you see water in your sink, most likely you can figure out why it is backed up before it gets higher than the stand pipe and goes into your dishwasher. Since you don't see the air gap device on top of the sink then I'm guessing whoever installed your dishwasher either put in a stand pipe and didn't put it up high enough, or more likely didn't put one in at all and therefore you are getting back-flow into the dishwasher.
dh
Nov 18, 2008 | Dishwashers
587 Doesn't work well
AS ABOVE SUGESTION ...PROBUBLY NOT GETTING ENOUGH WATER. NOT LIKELY THE FAULT OF THE DISHWASHER PROBUBLY SEDIMENT FROM THE WATER PLUGED THE INLET SCREEN OF THE FILL VALVE. MANY TIMES THE MOVING OF A FLEXIBLE PLUMBING LINE BRAKES LOOSE ANY SEDIMENT AND DEPOSIT DURING THE INSTALATION OF A NEW DISHWASHER WHICH IS WHY MOST ADVISE REPACING THIS SMALL FLEXIBLE LINE WHEN INSTALLING A NEW DISHWASHER. YOU WILL HAVE TO DIS ASSEMBLE VALVE TO CLEAN SCREEN ...IF YOU BOUGHT THE PROTECTION AGREEMENT OR HAD SEARS INSTALL IT THEY SHOULD COVER A SERVICE CALL TO CLEAN THE VALVE.
Jan 24, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Timer Knob Smegdishwasher sa 620x
I have this same model Smeg dishwasher. 1 = Soak - pans and dishes awaiting completion of the load. 2 = Strong - Very dirty pans and dishes dirt dried on. 3 = Normal - Normally dirty pans and dishes. 4 = Rinse - Dishes requiring "refreshing". If you would like a full copy of the user manual, send your address to "brockjack@g-node.com.au" and I will photocopy our manual for you.
Oct 06, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
99 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
