Question about GE Ovens
Oven door hinge detached from the oven
Somebody pulled the stove a " GE profile spectra stove" by the oven door and now the right door hinge is detached from the oven and the door is hanging by the left hinge. How do I put the hinge back?
Oven door detached from oven, what do you use to clue it back on. Glass door to frame section. any ideas
Posted on Jul 02, 2009
  • Neil Dec 19, 2012
    Hi,have same trouble,can you help me,what did you do to repair it,and cost etc neil
  • GE Master
  • 3,361 Answers
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
  • Neil Dec 19, 2012
    Hi Steve , please can you help me,I have same trouble ,what did you do to fix it,neil
I wish to remove oven door from oven on a Belling BI60MFB to re glue fascia glass .Can't see clearly how to detach.
Having searched it looks like a pull down oven door. It is normally a case of locking the hinge. How to fix your oven door glass Oven Door Glue has a video which shows several common types of hinge, and how to remove the door.
Nov 07, 2016 | Belling Ovens
How does one remove oven door on ge stove
Move the door to the broil position. Lift the door off the hinges. To re install the oven door the hinges must be in the broil position. Note: Some models have a screw on the inside door panel over each hinge that must be removed but I do not believe it is that way in your case. I looked at your model
If you are planning on replacing an element remember the L-2 off the breaker is LIVE to the elements. Make darn sure the power is OFF.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 21, 2011 | GE JKP15 Electric Single Oven
Top oven door will not close..appears left hinge not working
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Dec 15, 2009 | GE Profile JTP56 Electric Double Oven
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Replacing glass top on stove
I also have a ge spectra with a broken glass.
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
1,536 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
