Question about Logitech Squeezebox Duet
Logitech Squeezebox Duet Remote Control not working corectly
I brought the Squeezebox Duet Yesturday ,affter several hours letting the remote charge i went about setting it up ,but could not do this very easily as i had to leave the remote on the charging pod all the time.
As soon as i moved the remote or removed it from the charging dock station it would not work .
It would reboot up again each time i removed the Remote and the placed it back on the docking station.
This is brand New straight out of the box so it is very disapointing to have it not working as i exspect it to.
Is there something that can be done
Regards Andrew
  • Logitech Master
  • 4,524 Answers
I suggest you read the instructions to ensure you haven't missed some small detail.
If you are confident you have done everything right it is safe to assume the unit is faulty and should be returned to the retailer for replacement or refund and you should contact the retailer as soon as possible.
When a person buys something they actually are making a contract that in return for some hard-earned cash the retailer will provide an item of merchantable quality. If the item doesn't work as promised it is not of merchantable quality and the retailer has breached the contract.
Posted on Apr 16, 2017
SOURCE: remote doesn't recognize squeezebox duet
I have experienced the same connectivity issues with the Duet system. My first system was sent back for a replacement within the 30 day return policy. The second unit worked considerably better but the remote controller would still sometimes completely lose the link with the Squeezebox receiver after being left in the charger for an hour or two (or just set aside a while). Firmware upgrades seemed to slightly improve the situation, but I eventually sent the controller back for a replacement. The tech rep said they've had issues with the controllers. When I asked if I needed to return the receiver as well, he said "It's the controller, we've seen the problem quite a bit."
So, it seems the wifi function on the hardware can sometimes be defective. Update the firmware on everything, and if you've still got problems, insist on a replacement unit (it will likely be a refurb).
Good luck.
Posted on Feb 07, 2009
SOURCE: Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
Posted on Jun 20, 2009
  • 45 Answers
SOURCE: Hi i need a replacment battery for my squeezebox duet controller
Hi there, you can get this logitech remote control battery at batterytrader.com here
http://www.batterytrader.com/logitech-harmony-1905820000-remote-control-battery-p-7496.html
Posted on Jul 11, 2009
  • 101 Answers
SOURCE: harmony 880 won't charge
Try the steps outlined in the link below. This might help find the cause of the issue.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9168
Posted on Apr 14, 2010
SOURCE: Any known fixes for Logitech Harmony 880 universal
As an 880 owner myself, I think this is a common problem and documented out there on the internet.
This has happened to me a lot. (Okay, it's actually stopped now as the charged remote keeps shutting down and going into test mode.) But, back to your battery issue - I believe that the charging pins in the dock don't properly contact the equivalent pins on the back of the remote.
Try cleaning them with a Q-tip and rubbing alcohol, then press down. You should hear one beep only - if you hear a beep followed by another beep, the unit has made contact then lost it.
Good luck! I think this really is a design flaw.
Posted on Sep 14, 2010
Replace squeezebox boom battery
The battery for the Remote Control? That's the only battery a Squeezebox Boom has.
  1. Remove the back cover
  2. Replace batteries.
  3. Put back cover back on.
Download Logitech Squeezebox Boom Manual
Jan 24, 2014 | Logitech Squeezebox Boom Radio
Hi Just recieved a new wireless router with Talk Talk. I've tried to connect the Squeezebox remote and I can't access the server, the remote keeps displaying TRY AGAIN. I've uninstalled the software...
Hi !
You will have to change the wireless encryption key in order to solve this issue, if you are using WEP swap fpr WPA2 and vice versa, and no ASCII , HEX is way preferable for Squeezebox.
Thanks and have a nice day !
J -
Aug 15, 2010 | Logitech Squeezebox Duet
I replaced the batteries but the remote does not
Ur Lithium battery fully take in the charges,u recharges?Let the rmote sit without battery about couples hours.Put battery back in again,should work.
Apr 22, 2010 | Logitech Harmony 550 Remote Control
Trying to hook up logitech squeezebox
Hi. Slimserver is not supported anymore by Squeezebox systems, now you must download and install Squeezebox server 7.5.0 http://downloads.slimdevices.com/ This way it will install and works without problem. Thanks and have a nice day J-
Oct 17, 2009 | Logitech Squeezebox Duet
My logitech squeezebox receiver are not connected on squeezenetwork asking for pin i cant find my pin where can i find them
Hi, Please download the latest squeezeserver 7.5.0 and install it, The PIN code feature has been removed since version 7.4.1 Thanks and have a nice day ! J -
http://downloads.slimdevices.com/SqueezeboxServer_v7.5.0/
Aug 15, 2009 | Logitech Squeezebox Receiver Remote...
I need a new remote control for my tu160dtr
The make of the unit would be helpful, otherwise i found this at Amazon UK.
Jun 14, 2009 | Logitech Squeezebox Duet
No audio coming from logitech squeezebox duet
Did you try with the different connection method at the back of the receiver?
Are you talking about the remote jack ? This is normal, it still is a beta feature. Thanks to be a bit more specific if possible, Have a great day J-
Jun 03, 2009 | Logitech Squeezebox Duet
Squeezebox boom stuck in demo mode
Hi !
reset it !
Unplug the power cord , push and maintain the " + " button and replug the power cord, release " + " when you see " Factory reset ", then Fixed !
Have a gret day !
J -
Apr 17, 2009 | Logitech Squeezebox Duet
Remote doesn't recognize squeezebox duet
Good luck.
Jan 09, 2009 | Logitech Squeezebox Duet
Logitech Squeezebox Duet Logo
5,787 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
