Question about Hitachi 43FDX01B TV
Power problem? This just started happening recently, that when we have the tv and dining room lights on, the lights dim and the tv has thick black lines through it as if it is going to shut off. We shut the tv off and the lights were fine, when we put the tv back on the lights dimmed. We had an electrician check our power and he changed breaker to the house and checked the connection of the power lines to the house, we also had the power co check the lines to the pole and everything is ok. It all seems to come back to the tv, any insight would be helpful.
  • 979 Answers
Try th set in another room, if only to see if this phenomenom happens with other light fixtures or appliances. Would suspect the switching type supply in the TV as suspect if the problem "moves" with the set....accordianman
Posted on Oct 20, 2007
Can I hang a mirror in my dining room? What effect will it have?
You can hang mirrors on the wall by your dining room table. When you have guests, it will create an illusion of a very full house, adding warmth to the dining room area. If you light candles at the table, they will be beautifully reflected in the mirror.
Feb 18, 2013 | Home
Loud pop while fixing a light
That was the sound of arcing electricity. Most likely the fixture is shot...replace the wiring and the sockets and you should be fine.
Dec 16, 2012 | Furniture
What is the standard height of a kitchen/dining room table?
I was looking for dinning room tables which were standard size and came upon an interesting page at Macy's. They seemed to over a variety of shapes and sizes, many of which will cater for your needs in the kitchen, or dinning room for that matter.
May 29, 2012 | Furniture
How high above the dining room table should I hang my electric chandelier?
The height you hang your chandelier above your kitchen tabledepends on the wattage of the light bulbs and the of the chandelier. If you are using lower wattage light bulbs,you should hang the fixture about 2.5 feet above the center of your dining roomtable. If you are using higher wattagebulbs, I suggest hanging it 3 feet about the table so it is not too bright.
What is the difference between a kitchen and a dining room table?
Kitchen and dining room tables are generally the same. Except, sometimes dining room tables are a bit larger and made out of stronger materials.
I recently purchased a 47"
Your TV has a light sensor that changes the brightness of the TV based on room brightness.
It's called an "Intelligent Sensor"
You can turn this off in your "Picture" settings.
Congrats on such a nice TV purchase.
If this was helpful, please rank me a 4.
Mar 09, 2011 | LG Televison & Video
Different outlet went out after installing dimmer.
It's possible that he living room outlet feeds through the dining room switch and that a wire may have become disconnected when you put in the dimmer. I don't know the specifics of you home layout. If the dining room and living room are on different circuit breaker switches, this is not the problem.
Feb 28, 2010 | Electrical Supplies
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Hitachi 43FDX01B TV Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
