Cmos settings issue - Gigabyte MB
I have a gigabyte motherboard and I altered a cmos setting and now my keyboard, mouse and monitor do not work. I think it was some sort of power setting. How do I resolve this? or reset the cmos? anything really to help me would be appreciated. Thanks
    President:
  • 1,179 Answers
Reset the Cmos and it will revert to the default settings. You can then gradually bump up your settings until you find a stable platform and performs the way you would like. Hope this helps.
Posted on May 23, 2009
Gigabyte GA-965GM-S2 motherboard keyboard, mouse, monitor won't work.
You need all the drivers, each peripheral has it's own driver that needs to be loaded.
Nov 28, 2011 | Gigabyte GA-965GM-S2 Motherboard
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
Came home computer was on black screen and now it won't reboot. When I try to reboot, I get a "cmos checksum error ". Keyboard also isn't working. What could be the problem?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time & Date etc.
Sep 02, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
http://www.motherboards.org/mobot/manuals/Gigabyte/GA-686LX3/
Mar 29, 2009 | Gigabyte 440LX (GA-686LX3) Motherboard
My pc can't boot
Make sure the battery is facing the correct way.
Dec 25, 2008 | Gigabyte GA-6BX7 Motherboard
Gigabyte motherboard wont post
you have pry more, you have to invoq the god in you life, becose
i't's not posseble.
Aug 19, 2008 | Intel Motherboard
Gigabyte onboard vga is not default... no pci card
What you can do here is remove the Battery on your mobo. This will reset the CMOS and then you should be able to access your CMOS as usual. :)
Dec 25, 2007 | Intel Motherboard
CMOS battery drains after one startup. Gigabyte GA-K8N-SLI
OK lets see here! Make sure your CMOS jumper is set properly on the board(Set to Normal) or Did you configure your bios after flashing the bios(going into bios and Load Optimized Defaults!)? or I don't think it would be another device in the system, but you can try troubleshooting by starting up with only what you need to run the machine (Mobo, memory harddrive, keyboard and mouse) then one by one adding devices back! or Did you have problems like this b4 you flashed the bios! Try flashing the bios back to an older version! post back if anything new or if i'm way off! Good Luck regards, babb
May 03, 2007 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
