Question about Maytag PAV3240A Top Load Washer
Washer stopped during wash cycle, burning smell
Washer stopped during wash cycle. Burning smell water will not drain out. If motor burned out is it worth repacing?
    Problem Solver:
  • 17 Answers
Http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
Posted on May 23, 2009
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on...
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Mar 17, 2011 | Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stackable washer and dryer
check the belt, pulley, & idler pulley assy.
Jul 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Maytag PAV3240A Top Load Washer Logo
259 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
