Question about Mitsubishi WT-46807 46" Rear Projection Television
Rainbow line will come across screen and then goes blank. This is an intermittent problem. Normally if I turn it off and back on, it works. Now it does not.
My TV will be playing, then all of the sudden a multicolored horizontal line will appear and the screen will go blank. It is almost like it is overheating or something. It has been doing this intermittently for a month or two. Normally, I can turn the TV off and back on and it is back to normal. Right now, that is not working. Please help.
  • Mitsubishi Master
  • 8,617 Answers
Try resoldering the vertical output IC, the IC runs at a hot temperature and this can cause the Pins to have cracked solder.
Posted on May 24, 2009
Vizio TV has a horizontal 2mm black/multicolor line.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 27, 2016 | Vizio Televison & Video
Horizontal lines appear on 32" in some hd format movies.
The technician is right, the TV will not show such lines selectively. Try changing the input device to some other. Play some sure shot, genuine DVD.
Jul 19, 2012 | Televison & Video
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Jul 08, 2010 | Samsung LE32A457 32 in. LCD TV
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Black Horizontal Lines on Philips Cineos 50" Plasma
First you want to determine if the issue affects the tv's menu if it does you are looking at a Light Engine issue which is expensive if it does not interfere with the On Screen Display the issue is with your signal board, also check to see if this happens on multiple inputs with multiple signal sources if it doesn't you just might want to use a different input which is a way cheaper solution
Aug 06, 2008 | Philips 42FD9932 42 in. Plasma Television
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
ken@ikenfixit.com
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Mitsubishi WT-46807 46" Rear Projection Television Logo
152 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
