Question about Dryers
Having problems with the drum turning
I am having problems with the dryer starting. I have to hold in the button at the door and hold the start button then with my foot start the drum turning. After it gets started it works fine.
    President:
  • 1,136 Answers
Hi, you have a motor going bad. The start winding is out.
A motor cost around $95.00
Let me know if I can answer any more questions or assist you on part #'s and how to replace the motor.
Vic
Posted on May 23, 2009
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Oct 02, 2011 | Kenmore 63942 Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Mar 13, 2011 | Dryers
The dyrer will not turn on. The dryer makes a humming noise but will not turn on.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Also, check the blower on the dryer to see if a article of clothing may have gotten stuck there and preventing the motor from running.
Jan 22, 2011 | Whirlpool Dryers
When we press the button to start the dryer, we hear the buzzing but the dryer does not move.
Jan 09, 2011 | Frigidaire Electric Dryer
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
